Do you mean
Newbie
0
Unable to connect my LG TV dongle to HomeHub
I have tried several times to connect my tv dongle with no success.  It is finding the hub and has a good signal.  I select the auto connect function but it eventually fails and says 'Cannot connect with name server.  Check DNS server address and contact your ISP'  How can I overcome this failure?
0
Re: Unable to connect my LG TV dongle to HomeHub
Hi have you entered the security code Ito the device?
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
0
Yes I have done that .... it goes through the process of connecting and fails at the last hurdle.
0
Is there an option on the TV set-up to select a static IP address, including default gateway and DNS settings?
