Do you mean
0
Accepted Solution
Upload Speed Problems with Safari/Mail on iMac
[ Edited ]
Hi....Just moved to BT from Virgin where everything was all ok....running an iMac with latest Lion software and a Toshiba Laptop with Windows 7......everything is all ok except when I send an email from the iMac.....it's dreadfully slow.......RX is fine and fast.....both TX and RX are fine on the Toshiba. This upload problem is only there sending via Mail on Safari....uploading an MP3 say directly to MySpace is all ok......also if I access BT Yahoo Mail instead of using Mail/Safari then I can upload an attachment to Yahoo Mail no problem and my outgoing mail is instant and fast....so it seems that the BT Broadband Service doesn't like the TX side of my Safari Mail facility....I've tried rebuilding the Mail Account a few times and checked that all the settings are correct which they appear to be...any ideas out there please?....Cheers, Paul
0
Re: Upload Speed Problems with Safari/Mail on iMac
[ Edited ]
Can you measure your upload speed at Speedtester
How are you connecting to the mail server IMAP or POP3?
0
[ Edited ]
Had a look as requested.....doesn't seem to be applicable to my problems.....
0
I hit the wrong key, now edited.
0
download is 7.6mbits
upload is .26mbits
connection for email on the iMac is IMAP
0
upload is .26mbits
That is a very slow upload speed, I would expect a minimum of 448Kbs even on ADSL1.
What are your ADSL stats
Remember IMAP does exchange quite a bit of data.
0
ADSL Line Status
Connection information
Line state:
Connected
Connection time:
3 days, 19:33:32
Downstream:
7,616 Kbps
Upstream:
448 Kbps
ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Interleaved
Noise margin (Down/Up):
8.6 dB / 18.0 dB
Line attenuation (Down/Up):
12.0 dB / 8.0 dB
Output power (Down/Up):
19.7 dBm / 11.9 dBm
FEC Events (Down/Up):
262 / 8
CRC Events (Down/Up):
0 / 0
More Details
0
Baffling thing is that everything was ok with Virgin.....the line hasn't changed just the ISP provider....I suspect it's something to do with the IMAP facility?........
0
Just changed the BT Home Hub 3 for my original Netgear kit and it all seems back to how it should be........strange......is the new BT Hub not that good???....
Distinguished Guru
There's nothing wrong with that upload speed. The upstream sync is 448 exactly as you'd expect.
Certainly looks like an issue with macmail on the mac as uploads work fine on the other computer, and also via webmail, so that in itself proves that there's not a problem with the upload bandwidth of your connection.
