Do you mean
Newbie
Using A BT Home Hub (v.2) to extend Network
We have a BT Business Hub Network that handles our internal wired network and Internet access requirements. It also provides Wireless cover.
After renovations we have just moved the office to the back of the building, where there is no WiFi connectivity, but we do have wired ethernet connectivity that works (I'm using it now to write this).
We would like to use a spare BT Home Hub (v.2) as a network extender / bridge, providing:
Wider Wireless(WiFi) Coverage at the rear of the building
Wired ethernet connectivity - two PCs and a printer.
I understand that to make this work i have to -
Turn off DHCP on the home hub
Set a fixed IP address that is outside the range managed by the Business Hub
set the gateway to that of the Business Hub Gateway
Change the name and protocols of the Home Hub's Wireless network to match that of the Business Hub
Make sure that the Business Hub and Home Hub broadcast on different Wireless channels.
Once this has been done I should be able to plug in a PC to a Home Hub ethernet port and access the network, or access through the Home Hub's Wireless network
I have been able to change the wireless configuration, but not the any of the Broadband/Internet configuration values.
How do I change the address of the Home Hub without connecting to BT's ADSL service (I don't want to disconnect the existing service). The (annoying) user friendly software is stopping me from accessing the values I need to change.
All help much appreciated
R+C
Expert
Re: Using A BT Home Hub (v.2) to extend Network
[ Edited ]
Hi, and welcome.
What you are trying to achieve is here http://www.filesaveas.com/jarviser/repeaterhubswired.html whilst it uses 2 HH's the principle will be the same.
Hi
If I understand you correctly, you seem to be making heavy work of extending your network.
Why not just connect a cheap wireless ethernet router (not a adsl modem hub) to your existing ethernet connection
in your new office, and away you go. But remember your bandwidth will reduce with each additional connection you
make.
Hope this helps
Chas
Newbie
Chas
Yup I take the point about cheap - in this case free is the cheapest option and the Home Hub is free, so...
in this sort of situation the 'helpful' set up wizard gets in the way. Sad to say, this is "MUCH" easier with DTAG.
R+C
Newbie
Geaves
Thanks for that link, I'll go through it and report how I get on.
R+C
Expert
Uberseehandel wrote:
Geaves
R+C
Was wondering how you had got on with this, I have a 2700 as a back up and a spare HH2 to go with it.
