Do you mean
0
What Netgear router can I buy to use with BT Infinity?
I'm finding that the BT Hub 3 is totally unusable - it drops the wireless connection every 5 secons or so, I have tried changing to various channels 2,6,11 still the same problem
I've always had Netgear routers in the past and have never had any issues with them, can someone please recommend a good Netgear router that will work with BT Infinity
Thanks in advance
0
Re: What Netgear router can I buy to use with BT Infinity?
You need a cable router and not a modem/router as the modem (as you know) is the separate white box.
Something like this
http://www.maplin.co.uk/wireless-n-cable-router-224584?c=brilliant1&u=promo&t=netgear%20router&gclid...
For example
0
I just bought a Netgear WNR2200, and it works fine with the Infinity Modem. £45 from Maplins. It does what the HH3 should do, but doesn't...........KEYWORD BLOCKING......are you listening BT?
Guru
0
[ Edited ]
Is that a new security featureSmiley Very Happy because thats not all it lacks.
toekneem
(EASBF)
