Do you mean
Why isn't my E-mail working.?
I tryed to log in to Windows Mail. To access my BT yahoo e-mail Won't accept my password or e-mail address. Says it's wrong, So i tryed to log on to BT yahoo online, Works However, Comes up with Launch outage. Can't access E-mail.
What is wrong.?   And why is Windows Mail being like this.? Worked perfectly Earlier.
Thank's everyone will Appreciate it. Smiley Happy
JacobB
Expert
Re: Why isn't my E-mail working.?
Same here,
Maybe server down or something, nothing out of the ordinary with BT a!
Also have a look at this http://btbusiness.custhelp.com/app/service_status
cg
CG Over An Out
Thanks for the post, And sorry it is soo late.
Hopefully it get's sorted, And at least i'm not the only one facing this problem.
Jacobb
JacobB
aha not just mine deciding to be weird then? Smiley Very Happy
After pressing OK 20 times I decided to give up...
Expert
I`m also experiencing the same problem. None of my BT emails are working.
I originally thought it was just my connection acting up but it now seems not.
Hopefully BT get this sorted ASAP.
Expert
Just a little heads up...
 BT emails seem to be working again. Smiley Wink
Expert
My emails keeping dropping after I had posted a message on the forums then I had server interupptions now back to the original message I posted on the forum.  I was informed that there is a problem with Yahoo and that they know about for awhile and they still have not fixed it.  One moment my emails are fine and the next I have to go to classic, every year there seems to be a problem with the upgrade one as I can remember so BT and Yahoo sort it out or can I change my yahoo mail to something else any ideas.
I have seen All the upgrades, And yes when Yahoo gave the E-mail a fresh face. It annoyed me, And still does. Everytime i log in it freezes and all my "contacts" come up along the top.
I use Windows Mail or outlook if you don't have it, It is a good piece of software. Try that.
It may sort all your E-mail problems out.
JacobB
JacobB
