Do you mean
Newbie
0
Wifi,how do I stop wifi connections on BT home hub 2.0?
Hi,
I pay and use this hub and only use the cabled ethernet to my PC,not wifi.
Two other people live in my shared house and use their laptop internet connections through my BT hub 2.0.
Everytime one of them connects,my internet disconnects!
Is there a way of disconnecting wifi on the hub so only the cabled ethernet works?
Any help will be greatly appreciated
Thanks,mike
0
Re: Wifi,how do I stop wifi connections on BT home hub 2.0?
go into advanced settings on the router hub, enter the password, go to wireless and set it to no.
Distinguished Guru
0
Not quite
Home Hub v2: Go to 'Settings' > 'Advanced Settings' (Hub v2), select 'Wireless', then disable wireless connection
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Distinguished Guru
0
You first need to check whether you're a member of BT Fon because all new BT Total Broadband customers will be automatically opted into BT FON. Existing customers (since March 2009) will already be members of BT FON unless they have opted out.
If you don't opt out the facility to turn wifi off isn't available.
Alternatively you could set your hub into power save mode. This stops wifi connections but still allows wired connections. Set power save to a time when they're in!!
-+-No longer a forum member-+-
You could change the wireless encryption key and not tell anyone.
Distinguished Guru
0
or you could do as Keith suggestedSmiley Very Happy
I won't say owt if you don't!!
Recognised Expert
Copy & paste one of these. Smiley Happy
Ultra High Security Password Generator
A new very strong pass-phrase every time you refresh the page.
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
