Do you mean
Xbox Live connection via BT FON?
Hi,
I'm currently trying to get BT to sort a fault on my line, but in the meantime I wondered if I could connect to Xbox Live via a neighbours BT FON? When searching for networks through the Xbox 360 it gives me an error because there is more than one network with the same name. To my knowledge there are at least 2 other BT Hubs within range with a good signal.
How can I avoid this error and tap into a specific hub? And if it is possible how do I do this and will it work?
For reference I have a wireless adaptor on my 360 and a Homehub 2.
Thanks for any assistance on this matter.
