Do you mean
Guru
0
my experience tonight
set up box to record from the television scheduler before going out
1st program:
football on sky sports  1 set to record  match  at 15:44
this should havbe recorded to end of program at 18:30
instead it appears to have split into 2 parts a 25 minute first part from 15:44  & a second part  of 2hrs 23 minutes from 16:12
2nd program overlaps
Live NFL(Sky Sports 2) set to record from 17:30 - this again appears to have split recording - the first part  is 1hr 7 minutes , then a further recording from 18:36 of 1hr 21min   - this should according to the schedule had been 1 recording from 17:30to 21:00.
3rd program should have overlapped 2nd program
Live Spanish Football (Sky Sports 1)- starts at 20:00
I only have a blank recording of 2 minutes duration showing on my recorded programms list
4th Program
Live NFL(Sky Sports 2) set to record from 21:00 and should ave overlapped programs 3 & 5
This failed to record - according to my Scheduled  recordings page
I do have a blank recording of 2 minutes duration showing on my recorded programms list with a start time of 21:38
5th program (followed in the schedule from the 3rd)
Live Spanish Football (Sky Sports 2)- starts a 21:30
I have a blank recording of 2 minutes duration showing on my recorded programms list with a start time of 21:34
I have a  further blank recording of 2 minutes duration showing on my recorded programms list with a start time of 21:36.
I have a further blank recording of 2 minutes duration showing on my recorded programms list with a start time of 21:38.
I have a further blank recording of 2 minutes duration showing on my recorded programms list with a start time of 21:40.
5th Program
 Ford Football Special (Sky Sports 1) - starts 22:00 - scheduled end 23:30 - This appears to have recorded successfully
So out of 5 programs scheduled - only 1 has been correctly recorded.
Of course the helpdesk ()see other post) is not available to help
Impressed NOT
0
Re: my experience tonight
I think you would be better posting your problem in the BT Vision forum.  you will hopefully get a quicker answer there
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
