Do you mean
wi-fi password
i am trying to connect an ipad to my wi-fi but it does not recognise my password, is there any way i can find out what my password is?
Re: wi-fi password
Are you looking for your wireless password if you are unless you have changed it yourself it it on the card supplied with your home hub
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Re: wi-fi password
Hi,
If you haven't changed your password since installing your hub, then it will be written on the back.
Kyle
If you found my post helpful, please give Kudos on the left!
Re: wi-fi password
must type faster lol
Try a Search
Recognised Expert
Re: wi-fi password
[ Edited ]
If you use the hub the pass word is shown on the wifi security page
if hub
enter for homehub
192.168.1.254 in browser click A to Z top right
then Wireless security enter pas
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Re: wi-fi password
Hi iggy,
 Wireless Password will be present in the back of the Hub
If you have problems connecting to Wi-Fi in the IPad try changing the Wireless channel of the Hub or try changing the Wireless key type from WPA to WEP
Recognised Expert
Re: wi-fi password
Only if left set to default
