FredKruczko
Newbie
Message 1 of 4
1000 ping+ after 12pm
after a certain time of night my internet decides to just cut back and go to 1000+ ping and very bad net download speed
3 REPLIES 3
Message 2 of 4
Re: 1000 ping+ after 12pm
Welcome to this user forum.
Probably interference to your broadband connecton, or your wireless connection, if you are using wireless.
See https://kitz.co.uk/adsl/rein.htm
FredKruczko
Newbie
Message 3 of 4
1am onwards (lag)
while im playing video games past 1am i seem to run into the worst wifi this planet has seen when nothing or no one is awake and no downloads are downloading i have jumps on discord from 30-2600+ help pleaseeee
Moderator
Moderator
Message 4 of 4
Re: 1am onwards (lag)
Hi @FredKruczko,
If you are looking to avoid lag you would be best using a wired connection instead of WiFi. WiFi can pick up more interference and can increase latency.
Try connecting with hardwired and let us know if you've noticed an improvement.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
