Message 11 of 13
Re: 2 Houses 50 yds apart - INFNITY available to 1, not other!!!
great result
thanks for update
Nickaminsky
Message 12 of 13
@john46 wrote:
If you use this checker it will tell what cabinet you are on and what services it can receive.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If it does not show a cabinet number it will be because you are on an Exchange Only line which will mean you can not get Infinity because you are not connected to a cabinet, instead you are connected directly to the exchange.
qq. If you're on an exchange only line (like me) will we ever be able to get Infinity? Is it something on the BT/Openreach road map at all?
Message 13 of 13
people on EO will get fibre as openreach are building cabinets just outside the exchange although that is mainly after the current rollout.  If you search through infinity board you will find some where they are now connected and others where the cabinet is/has been erected already
