paulfurlong79
Message 1 of 16
2-Wire 2700HGV BT Business Hub
Ok I am at my wits end with this new HH3. It just cant cope with SNR of 3.5 which my line drops to at about 11pm every evening for about 10 mins.
I have invested in a brand new 2-Wire 2700HGV Bus Hub.
My question is which I probably should of asked before buying it. Is it possible to configure it to work with BT home broadband without flashing etc
If so HOW?
Please help or advise and if necessary il cancel my order
15 REPLIES 15
Message 2 of 16
Re: 2-Wire 2700HGV BT Business Hub
should work plug and go  just enter user as bthomehub@btbroadband.com and no password required.  if router insists then any thing will do
raymie67
Expert
Message 3 of 16
mant use it but in case you did not know you can get new ones from ebay for under £20 so if you are ordering fro BT you may want to look there first
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
Message 4 of 16
The best buy you will make in a router excellent on long lines and very stable connection speed
06jpearce
Message 5 of 16
Did you buy this direct from BT? As I have got one and they are fab. It better wifi even goes to the 8th bedroom and hub 3 did not! It may cause problems with tech support as when I had no connection it was like being interviewed for murder!
paulfurlong79
Message 6 of 16
I got mine form EBAY. Dont think i was going to pay full price did ya 😉
Its sealed so brand new apparently
paulfurlong79
Message 7 of 16
When you first plug it in is it easy to complete setup / start setup
what about updates to firmware as I hear it only works on Business broadband lines for updating
Message 8 of 16
if there are any updates it will get them automatically mine has and it on a residential line
they are plug and play just follow the username set up make sure you use bthomehub@btbroadband.com password not needed if you want one chose your own
Message 9 of 16
06jpearce a good reason to stay away from the help lines
Heathy71
Message 10 of 16
Ive been using one for 18 months that i got of ebay, I was sick of the HH2 reseting itself when online with the xbox.
It has been trouble free and hassle free, works fine on a residential line.
Why cant the home hubs be link this?
