dominice
Message 1 of 11
ADSL G.dmt to ADSL2+ modulation change
Hi,
Hopefully someone can shed some light on what I need to actually ask BT to get this resolved, as their customer care is beyond incompetent.
Basically we have an issue with an ADSL connection and the speed fluctuating (going between 0 and 8mb quite rapidly and then dropping out), however, we're in a town centre and pretty much on top of the cabinet.
After the first two hour call, I got through to an advanced technical support team who said the issue would more than likely resolve itself if we moved to BT's new 21CN network and got the full ADSL2+ speed and not the ADSL G.DMT speed we're getting at the moment. I know we're on the old network and not ADSL2+ because that's what the router says the modulation rate is.
I thought two hours was bad enough, however as the technical assistant couldn't force our line to the new ADSL2+ we then got passed to sales, then back to technical and round.. and round.. and round.. for a further three hours while someone tried to work out what was going on.
From what I can gather, sales say our account is on ADSL 2+, however technical (and what is actually happening) is on the old G.dmt network. Therefore there needs to be some alignment between the two systems to actually get us correctly onto the ADSL2+.
I've been told it's order management who would ultimately do this, however they're now saying it's technical.
BT has to be the worst company for actually know what's going on - there doesn't seem to be a single person who can take control and sort it.  There's always another department to fob you off to.
If someone can shed some light onto how I get this resolved, it would be much appreciated.
Thanks,
10 REPLIES 10
Message 2 of 11
Re: ADSL G.dmt to ADSL2+ modulation change
I have asked a forum moderator to help you they will post their contact link here
Moderator
Moderator
Message 3 of 11
Hi @dominice,
It sounds as if our records shows we ordered ADSL2+ for you but BT Wholesale, our suppliers, have kept you on ADSL Max. Some of the people you've spoken with seem to only check our systems instead of contacting our suppliers to make sure all is matching. This is something that I, or any of the mod team, can do. You can reach us by clicking on my user name and then on contact the mods.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
dominice
Message 4 of 11
Hi @DanielS
Thanks for the reply.
I've raised a contact request, hopefully they'll be able to review where the issue has occured.
Thanks,
Moderator
Moderator
Message 5 of 11
You are very welcome @dominice.
It's taking about 5-6 working days for a reply but we will be able to look into it for you.
DanielS
Kudos”
dominice
Message 6 of 11
Hi @DanielS,
I posted the message over on the 14th, 7 working days ago now, are you able to confirm it was received?
Thanks,
Message 7 of 11
the mods are very busy at the moment you would have received a tracking reference as soon as you sent the contact the mods form
Moderator
Moderator
Message 8 of 11
Hi @dominice,
I had a look and can see that we've received your details. The telephone number for your Broadband account seems to be linked to a Business account and your email has been sent to the business team to deal.
Unfortunately the forum moderation team are only able to deal with residential account.
PaddyB
Community ModeratorPaddyB
Kudos”
dominice
Message 9 of 11
Great, so I'm no further forward two weeks later then.
How do you propose I actually get this sorted as it seems no one at BT is able to.
Message 10 of 11
your information has been passed to the Business team and they will contact you and resolve your problem this forum is for residential customers only
