Addy
Message 1 of 4
ADSL Max and ADSL 2+
Hi,
I'm on ADSL Max ( image below) for as long as I can remember and also very close to the exchange. In the past when I've queried about the 17mb copper broadband I've always been told it is not available. However, due to the proposed price increases, I've been checking options and used the broadband checker to see what fibre speed I might get. The checker (image below) shows something called WBC ADSL 2+ is available with speeds between 10 - 19mb. Using the BT product and services website the address checker shows (image below) similar download speeds 10- 19mb. Does this mean the higher speed is now available on my exchange? If so is it possible to move from ADSL Max to the ADSL +2 and how is this done. I tried ringing but just end up in a loop where I'm told the only options are to move to infinify.
thanks
Ade
3 REPLIES 3
Message 2 of 4
Re: ADSL Max and ADSL 2+
the mods will help and post a here just follow their link
Moderator
Moderator
Message 3 of 4
@Addy we'll be happy to look into this for you. Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Addy
Message 4 of 4
Hi @NeilO I've submitted the details via the link in your message, many thanks
Addy
