Blatcho
Message 21 of 48
Re: ADSL Max, extremely slow following phone fault (0.1Mb download at best)
Out of interest, why the reluctance to reset manually, if it will resolve the issue quicker? I'm not sure I see the benefit in waiting if there is an alternative approach? Perhaps administrative effort I guess..
Also, I've just had a call from BT who have advised me to restart my Hub, as they are resetting the IP Range manually - now, i'm in a bit of a quandary, as to date this forum (and yourself) have been far more responsive than BT directly, but perhaps they're talking about the exact thing you mention?
Tags (1)
Blatcho
Message 22 of 48
OK literally 5 minutes after the call from BT, these are the results I'm seeing - quite the improvement!
 Download speedachieved during the test was - 1.8 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.68 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 3 Mbps
Message 23 of 48
profile now correct for your connection speed
Blatcho
Message 24 of 48
..and I'm back - same old problem, IP Profile down to 0.33, another ticket raised with BT. Broadband has been up ever since the last time I visited this forum, albeit intermittently slow, typically within the rang of 0.5 - 1. This is just about acceptable, but when it drops below the 0.5 mark, it just becomes a pain in the a$$, streaming/downloads/multi-device usage is just awful.
I've gone through all the usual tests, can anything be done?
Download speedachieved during the test was - 0.33 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
 Your DSL Connection Rate :0.51 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.35 Mbps
Thanks..
Chris
Tags (1)
Message 25 of 48
this not same as before   last time you has 3mb speed but low profile whereas this time your speed is only 0.51mb and the profile is correct for that speed.  can you post the adsl stats from your router please
are you conencted to test socket or have you moved?
try quiet line test and check for noise as something has caused your connection speed to drop
Message 26 of 48
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Blatcho
Message 27 of 48
OK here we go, thanks..
 Download speedachieved during the test was - 0.32 Mbps
 Your DSL Connection Rate :4.26 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 00:06:56
Downstream:4,256 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.6 dB / 19.0 dB
Line attenuation (Down/Up):52.5 dB / 31.5 dB
Output power (Down/Up):19.7 dBm / 11.9 dBm
FEC Events (Down/Up):437 / 1
CRC Events (Down/Up):2 / 0
Also, this is what the BT site test shows -
Message 28 of 48
that last reset about 6min ago restored your conenction speed back to 4.2mb but profile still at 0.35mb due to the previously low conenction speed of about 0.5mb.  you now need to maintain a stable conenction 24/7 for 3/5 days maybe sooner and your profile should recover automatcally
Blatcho
Message 29 of 48
Ah, ok, thanks imjolly - so what's the recommended best practice, should i restart my hub on a regular basis to ensure the connection speed logged is up-to-date, and therefore my IP profile reflecting actual speed?
Message 30 of 48
no the best thing is a stable connection 24/7 with no resets.  if you maintain conenction then profile will correct itself
