Blatcho
Message 41 of 48
Re: ADSL Max, extremely slow following phone fault (0.1Mb download at best)
Hi all, today's stats - IP Profile has not shifted at all, boo..
Download speedachieved during the test was - 0.32 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
Additional Information:
Your DSL Connection Rate :4.19 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.5 Mbps
Message 42 of 48
so connection speed has now recovered to 4.19mb just a matter of waiting for profile to catch up - could be 3/5 days maybe sooner provided stable connection
Blatcho
Message 43 of 48
Trouble is, the DSL Connection Speed keeps fluctuating between > 4 and < 0.5, meaning the IP Profile never catches up. I'll see what happens over the next few days..
Message 44 of 48
are you still in test socket?  has that enabled you to maintain conenction and no drops?  if so maybe there is a problem with your SSFP although unusual it is not unknown for that to cause a problem
Blatcho
Message 45 of 48
Yes still in the test socket, has been since the original issue was 'fixed' - still no change to my IP Profile, apparently BT are calling back this evening, so that's something to look forward to...last time, they had no clue what an IP Profile was. Love it.
Tags (1)
Message 46 of 48
has your router dropped connection as that may well be reason profile has not improved?  can you post stats from your hub?
Blatcho
Message 47 of 48
Nearly up for 3 days, hopefully BT can sort - once they actually agreed that the IP Profile was the issue last time around, they fixed it almost instantly, it's just getting to that stage is often incredibly painful..
Line state:Connected
Connection time:2 days, 21:38:13
Downstream:4,192 Kbps
Upstream:448 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):4.3 dB / 19.0 dB
Line attenuation (Down/Up):52.0 dB / 31.5 dB
Output power (Down/Up):19.8 dBm / 11.9 dBm
FEC Events (Down/Up):1894851 / 185
CRC Events (Down/Up):2255 / 130
Message 48 of 48
hopefully you can maintain connection 24/7 and profile should correct itseld in 3/5 days.  correct profile is 3.5mb based on your current connection speed
