dspit1664
Message 1 of 8
ADSL - home hub4 poor wifi
Hi,
fisrt post so be kind 😜
Provider BT - Only have ADSL / Homehub 4 - ~DL 9Mb / UL ~0.9 Mb
we get very poor/slow wifi even when we're sat directly next to router.
Ive tried changing  the channel multiple times yet nothing helps.
Im thinking of swapping out the HH for a Draytek 2860 range router.
Before I do can anyone recommend what to do to troubleshoot my HH to try and improve wifi ?
fwiw - we've got little hope of getting FTTC in foreseeable.
Thnaks for for help in advance. Cheers
7 REPLIES 7
Message 2 of 8
Re: ADSL - home hub4 poor wifi
the draytek 2860 is just a router not modem router so you need a separate modem
have you tried a factory reset of your hub by pressing recessed button on back and holding till lights flash - 20/30 secs
are you still in fixed term contract with BT?  if so and reset does not help then phone customer services and ask for replacement hub as wifi not working on current hh4
many on forum use a tplnk 9970 and get good reports - and only £35/40
dspit1664
Message 3 of 8
Hi @imjolly, many thanks for reply.
Wifi does work just really slow.
Have tried reset and change channel.
So just request new HH ?
We're out of contract too btw 👍
Message 4 of 8
if you are out of contract then up to you about router as BT won't replace hub for free
you are also now back on standard terms and paying way to much for your broadband  if you decide to renew and save money phone options team 0800800030 and negotiate a new deal and new hub
dspit1664
Message 5 of 8
Thanks good suggestion. Will call them and give them first dibs at keeping our business 👍
dspit1664
Message 6 of 8
To add even if we chose to stay with them would still be thinking of getting my own router (with modem). Have many devices connecting via powerline and some wifi. Would getting my own router with better spec help ?
Message 7 of 8
as I posted the tplink 9970 is popular and appears to give good coverage but is only single band 2.4ghz  that may not bother you and it should work with your powerline adapters
dspit1664
Message 8 of 8
Thanks for clarification have devices which can work with 2.4 & 5 - so may look at a device which provides both.
