DiggerOfTrenches
Message 21 of 30
Re: ADSL2 missing and router not connecting
@imjollywrote:
as you left BT and went another ISP and are now back were you not considered a new customer and sent a new hub?
can you enter your phone number and post results remember delete number  https://www.dslchecker.bt.com/adsl/adslchecker.welcome    this will help should you need mod help for adsl2
is your phone line working - dial 17070 option 2 is your number correct and line quiet
Can you do this as well. Line goes silent listen for hiss crackles and pops. Please report back findings. No noise is bad news. Noise makes it quicker. I'll explain on report.
DiggerOfTrenches
Message 22 of 30
Does your master phone socket look like any of these?
Master socket with one socket
Master socket with two sockets
If so which one?
DavidM
Moderator
Moderator
Message 23 of 30
Hi @castlemaster  and welcome back.
Thanks for posting the stats etc. It looks like we'll be able to move you over to ADSL2 but there might not be a lot of improvement. It's worth trying though. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
In the meantime can you try connecting the hub? Let me now if that improves anything.
Cheers
David
castlemaster
Message 24 of 30
I don't have that screen on my home hub 4, it's very limited indeed it seems.
castlemaster
Message 25 of 30
Re: DSL Modulation - ADSL_G.dmt
Yes I am 🙂
castlemaster
Message 26 of 30
YEs I've tried test socket already, made no difference, tried different cable from modem as well as microfilter too.
castlemaster
Message 27 of 30
Yes, it's the bottom right one I have
castlemaster
Message 28 of 30
Quiet line test is inded quiet, no pops, whirrz, buzzes or fizzes 🙂
castlemaster
Message 29 of 30
I have replied to the PM, thanks
DavidM
Moderator
Moderator
Message 30 of 30
Thanks for letting me know @castlemaster . Leave it with us and we'll be in touch soon.
Cheers
David
