Shadowfire
Message 1 of 6
Activated on ADSL Max not ADSL 2 / 2+
Hi,
As experienced by other user on this forum I appear to have been activated on ADSL Max rather than ADSL 2/2+.
Would it be possible to move me across?
On my previous supplier I had a solid ~10500\800Kbps ADSL 2 connection, I now seem limited to 8096\448Kbps. The limited upload is the real issue for me.
Cheers & thanks in advance,
Mark
1. Product Name: HomeHub4
2. Serial number: xxxxx
3. Firmware version: v0.07.00.1729-BT (Type B) Last updated [Unknown]
4. Board version: 01A
5. DSL uptime: 3 days, 21:44:55
6. Data Rate: 448 / 8096
7. Maximum Data Rate: 1188 / 8136
8. Noise Margin: 26.0 / 6.1
9. Line Attenuation: 21.0 / 29.0
10. Signal Attenuation: 0.0 / 29.0
11. Data sent/received: 337.4 MB / 4.9 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
14. 2.4GHz wireless network/SSID: BTHub4-R3N9
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA & WPA2 (Recommended)
17. 2.4GHz wireless channel: Automatic (Smart Wireless)
18. 5GHz wireless network/SSID: BTHub4-R3N9
19. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))
20. 5GHz wireless security: WPA2 Only
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: xxxxx
24. VPI/VCI: 0/38
25. Modulation: G.992.1(DMT)
26. Latency type: Fast
27. Software variant: -
28. Boot loader: 0.4.3-BT (Mon Jun 9 14:23:56 2014)
 ADSL checker seems to think I could\should be on ADSL 2
WBC ADSL 2+Up to 7.5--6.5 to 8.5Available
ADSL MaxUp to 7.5--6.5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Copper Multicast------Available
5 REPLIES 5
Message 2 of 6
Re: Activated on ADSL Max not ADSL 2 / 2+
I can't see any reason why wholesale put you on adslmax apart from the estimated speed is the same for adslmax and adsl2.  the mods wuill help and will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Moderator
Moderator
Message 3 of 6
Hi Shadowfire,
Thanks for posting and welcome to the community forum.
I can help you with the upgrade from here.  Click on my username and under the "about me" section of my profile you'll see the link to get in touch with us.
Cheers,
Robbie
Shadowfire
Message 4 of 6
Thanks imjolly & Robbie!
Reference number is 141230-******
Cheers,
Mark
Shadowfire
Message 5 of 6
Hi Guys,
Line was moved over to ADSL2 yesterday and speeds are good. However, whenever i use the phone the adsl drops. There is also random intermittant noise on the line. Is this due to a line fault? I've tried all the usual swapping router\filters\phone & using the test socket with the same result.
Cheers,
Mark
5. DSL uptime: 0 days, 00:01:00
6. Data Rate: 1155 / 10247
7. Maximum Data Rate: 1168 / 10340
8. Noise Margin: 5.8 / 6.0
9. Line Attenuation: 20.4 / 32.5
10. Signal Attenuation: 20.9 / 40.3
11. Data sent/received: 0.3 MB / 0.4 MB
13. BT Wi-fi: No
14. 2.4GHz wireless network/SSID: BTHUB4-R3N9
16. 2.4GHz wireless security: WPA2 Only
18. 5GHz wireless network/SSID: BTHUB4-R3N9
24. VPI/VCI: 0/38
25. Modulation: G.992.5(ADSL2+)
Message 6 of 6
if you have tried all the usual - test socket new filter etc - then it would appear to be a line fault which you need to report to 151
