Moderator
Moderator
Message 51 of 71
Re: Actual Speed versus Contract Speed
Hi @lyn6 I have checked and can see that you have an appointment booked for Friday. Post back after the visit to let us know how you got on.
cheers
John
lyn6
Message 52 of 71
Will do @JohnC2. External fault was supposed to have been fixed by 5pm today but there has been no change. Speed has now dropped to a constant 2.5mbps for the last few days 😞
lyn6
Message 53 of 71
@JohnC2
Update:
BB speed had been getting worse and worse until it was left that 1mbps the last couple of days.
BT phone engineer called today(1/12). Tested the line and could find no fault but noted there was noise on the line. As a precaution he replaced the cable between the pole and the property as it was old and showing signs of wear and may have been causing the problems. Not noticed any significant improvement so far but will give everything a couple of days to settle
Message 54 of 71
Can you post the stats from your hub see if they have changed
lyn6
Message 55 of 71
@imjolly
BT BROADBAND AVAILABILITY CHECKER
Telephone Number  on Exchange BIDEFORD is served by Cabinet 26
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateWBC FTTC 18x2 Provide AvailabilityWBC FTTC 18x2 Sim AvailabilityLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date       ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date     Left in JumperOther Offerings     Availability Date       Premise environmentStatus
VDSL Range A (Clean)8071.7201964.6Available----Yes--
VDSL Range B (Impacted)8066.8201955Available----Yes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 4.5--2.5 to 10Available--------
WBC ADSL 2+ Annex MUp to 4.5Up to 0.52.5 to 10Available--------
ADSL MaxUp to 3.5--2.5 to 6.5Available--------
WBC Fixed Rate1----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date10-01-2017
Message 56 of 71
@lyn6  Sorry it the hub stats. Advanced settings then technical log
Moderator
Moderator
Message 57 of 71
Hi @lyn6 I've checked the engineer's report and a section of external cable was replaced. Is the buzzing noise still on your line or is the line now clear?
Also please can you post the Hub Stats as per @imjolly's post.
Cheers
John
lyn6
Message 58 of 71
Hi @JohnC2
Phone line is now great thanks
Sorry @imjolly I thought I'd done this the other day.
his is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ71866797
Firmware version:
SG4B1000B316
Firmware updated:
02-Sep-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 8 Hours 32 Minutes 56 Seconds
Data rate:
443 Kbps / 6.59 Mbps
Maximum data rate:
1052 / 7732
Noise margin:
27.6 dB / 10.1 dB
Line attenuation:
41.5 dB
Signal attenuation:
19.4 dB / 41.5 dB
VPI / VCI:
0/38
Modulation:
G_992_3_ANNEX_A
Latency type:
Fast Path
Data sent / received:
16401 MB Uploaded / 20532 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C3HP
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-C3HP
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:FF:49:63
Software variant:
Boot loader:
7.33.1
Message 59 of 71
If line now clear then need noise margin reset back to 6db which should give a bit more speed - attenuation still at 41.5db. Also I think at same time you need the cap taken off the up speed as it should be 100% faster - hopefully mod will sort both at same time
lyn6
Message 60 of 71
I'm liking what you're telling me @imjolly 🙂 🙂
