Message 61 of 71
Re: Actual Speed versus Contract Speed
Hopefully @JohnC2 will check back and see my post and then help make changes to your connection
Moderator
Moderator
Message 62 of 71
Hi @lyn6 Thanks for posting that information back and cheers to you @imjolly 😉 I've placed the order to make those adjustments to the profile and they will complete within 24hrs.
Cheers
John
lyn6
Message 63 of 71
The adjustments have all been done and I'm now up to the heady speed of 6.2mbps. This may not sound much to some but as I had less than 1mbps a week ago and was only ever promised 8mbps by BT in this area, this is a good result.
You guys really are amazing and I can't thank @imjolly & @JohnC2 enough for your help and patience getting this sorted. Heart
Message 64 of 71
did you up speed increase as well like expected?
lyn6
Message 65 of 71
@imjolly I've gone from less than 1mbps last week to 6.2 this week. BT only ever promised 8mbps so I'm not sure what to expect???
Message 66 of 71
I was hoping the up speed would increase to somewhere 0.8/1mb. As you say your have seen a great improvement in your down speed with mod help
lyn6
Message 67 of 71
@JohnC2 sorry I missed you again. I've texted to close the case as  beleive you've done everything you can for now. If speed drops significantly again then I'll start a new case. Once again thank for you time & patience
Moderator
Moderator
Message 68 of 71
Hi @lyn6 Thanks for posting back and sorry for the problems when trying to speak with you on Thursday. I will close the case off and hopefully there will be no significant drop in speed in the future. 🙂
Cheers
John
lyn6
Message 69 of 71
Just a quick update...................... I've given up!!!! Speed is back below 5mbps (mostly below 4mbps) so I'm ditching ADSL for fibre - kind of think that was what BT wanted all along. Thanks again to you all for your help and sorry I've not been able to stick with it.
xxx
Message 70 of 71
You must be quite close to the cabinet, so you should get maximum speed on BT Infinity 1, and 2.
ADSL can be a bit variable when you are a long distance from the exchange, which is why FTTC was installed.
