Do you mean
Newbie
Adding a wireless repeater
I would like some advice on How to connect a wireless repeater to my broadband router.
I have a BT HomHun v1.0 firmware 6.2.6.H.
I have just purchased a WAP from TP-Link (TL-WA901ND) and would like some advice on how I may connect to my home network. I use a Dell desktop which has two NICs one unused whilst the other is connected to the homehub router. Any advice welcome.
Re: Adding a wireless repeater
you might find some assistance here http://www.jarviser.co.uk/jarviser/homehubindex.html
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
Newbie
Thanks will give it a try!
