Message 41 of 52
Re: Non Rate Adaptive ADSL(0)Max. ie. DLM switched off 6dB Fixed Margin. BLACKLISTED.
Update:
02/05/19 No user input router reboot 7pm aprx. Need to inspect logs properly. Later.
It's been raining this afternoon. I've been expecting a retrain not a reboot due to rain affecting capacitance and insulation resistance of line thus bleeding of high frequency bins. Sync better than expected, looking good. I've cursed it now!
T.B.C.
Message 42 of 52
Reboot on 03/05/19 @ 10:48 am orders sent from HQ.
Still looking good dare I say.
Message 43 of 52
FYI 'stabilisation period' ADSL2plus with upload cap. -1dB? A 6A lie?
As well as up means down , down means up... and fast path = anything.
19/04/19
Message 44 of 52
Day 9? of 10. stabilisation period. In logs. Too tired to comment.
Message 45 of 52
day 9 st. ping london.
Nay bad.
Message 46 of 52
Message 47 of 52
@NeilOwrote:
@DiggerOfTrenches Welcome back to the community and thanks for your questions. I've moved your posts back to your original thread as its best to keep them in the one place which makes it easier for the community to follow.
DLM is active by default on all ADSL2+ lines
The standard target SNR margin is 6db if your line is good and error free DLM may choose to reduce this to 3db in due course if your line is suitable. The connection is rate adaptive and designed to give you the best speed your line can carry stably.
Yes your line will be in a new 10 day stabilisation period after the changes @JohnC2 made yesterday.
There are no blacklists, I suspect that due to the previous issues with the line DLM had reduced your connection speed and raised the SNR margin to try and stabilise the connection and keep the connection up. This is normally reset after a repair to the line is made.
Message 48 of 52
So.....
Day 10 of stabilisation. ET has finally phoned home. Looking good dare I say.
Screenshot from 2019-05-06 15-49-29.jpgScreenshot from 2019-05-06 15-50-22.jpgScreenshot from 2019-05-06 15-50-34.jpgScreenshot from 2019-05-06 15-50-45.jpgScreenshot from 2019-05-06 15-50-55.jpgScreenshot from 2019-05-06 15-51-04.jpg
Message 49 of 52
Is that the 'tinkle, tinkle, tinkle pause ding' of Openreach coming or not in the morning? 20:52pm
Message 50 of 52
22:45 more Hub 6A drivle. -0.2dB it thinks it's a DG834GT. In it's dreams. Hold on Lesley.
Wo Lesley.
