Brandscill
Message 1 of 19
Alternative Modem to HH4
Hello
I've just ordered the unlimited package and wondered if I could use a standard ADSL modem as opposed to the HH4 and then connect this to my own router?
If I can, does anyone have any reccomendations?
Alternatively has anyone had much luck using the HH4 in a bridged mode to a normal router?
Thanks.
18 REPLIES 18
Message 2 of 19
Re: Alternative Modem to HH4
Welcome to this forum.
The home hubs cannot operate in bridge mode, but there is nothing to stop you using another ADSL modem/router.
Brandscill
Message 3 of 19
I can't access that site as I don't yet have BT broadband. How come you've blocked it from other providers?
Message 4 of 19
it is a personal site which belongs to Keith and for use only for BT broadband clients
Brandscill
Message 5 of 19
Fair enough, well can you give some idea of the content there as I assume the link was relevant to my original question?
Message 6 of 19
are you getting adsl or fibre?  if adsl then you can use your own modem/router
Brandscill
Message 7 of 19
ADSL. Do you have any suggestions for just a modem, no router?
Message 8 of 19
a router is a better option as broadband is an always on service your connection speed will be affected by the modem being turned on and off to often
Brandscill
Message 9 of 19
Why would I be turning the modem on and off? I just want a standalone modem that can connect via ethernet to a standard wireless router (that doesn't have the ADSL modem built in)
Message 10 of 19
ok understood now I thought you were using a modem only in that case any modem you like can be used
