Tonyh10
Message 1 of 18
Another ADSLMax to ADSL2+ request
Hi, I'm a new BT Unlimited Broadband customer on an exchange that's had ADSL2+ for several months. My previous ISP contract was for ADSLMax only so I'm looking forward to some slight speed improvements, especially upload. However, the Home Hub 4 is connecting with G.992.1 Annex A modulation. I have to say that I'm astounded that I seem to have to come here to get that changed to ADSL2+ (G.992.5 Annexe A modulation), but I'll be grateful for advice on how to achieve that!
Anyway, BTW Speedtest results are:
Download speedachieved during the test was - 5.42 Mbps
 For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
 IP Profile for your line is - 5.36 Mbps
Upload speed achieved during the test was - 0.36Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
HH4 log info:
09:45:22, 09 Feb.( 84.570000) DSL noise margin: 26.00 dB upstream, 6.40 dB downstream
09:45:22, 09 Feb.( 84.500000) DSL line rate: 448 Kbps upstream, 6080 Kbps downstream
The BT Broadband Availability Checker gives:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+Up to 4--3 to 7Available
WBC ADSL 2+ Annex MUp to 4Up to 0.53 to 7Available
ADSL MaxUp to 3.5--2.5 to 6.5Available
Fixed Rate2 ----Available
Other Offerings
Copper Multicast------Available
Thanks,
Tony
Tags (2)
17 REPLIES 17
Message 2 of 18
Re: Another ADSLMax to ADSL2+ request
wholesale have put you on adslmax as your speed will probably not exceed the 8mb adslmax limit.  the mods will post a contact us link and see if they can get you upgraded
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Moderator
Moderator
Message 3 of 18
@Tonyh10 welcome to the forum and thanks for your post about your broadband connection. We'll be happy to check this out for you if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Tonyh10
Message 4 of 18
Thanks @, you may well be correct, but it's a pity they seem not to take upstream speed into account as well.
@JohnC2, I'm pleased to have your quick response, thanks. I've completed the contact form.
Regards,
Tony
Message 5 of 18
they never do just down speed - there are many posts like yours from new customers
Tonyh10
Message 6 of 18
I've just noticed that there's now a fault report in place on MyBT (I assume for my request), so thanks for instigating that so quickly. Its date/time is even slightly prior to my first forum post with the request! I'll keep tracking its progress and let you know when there's anything to report.
Tony
Tonyh10
Message 7 of 18
@JohnC2 The 9 Feb fault report on MyBT has now changed to Current Status: Completed, but my connection is still stuck on ADSLMax.
After a restart, the HH4 Event Log / WAN gives:
11:22:53, 15 Feb.( 93.960000) DSL noise margin: 27.00 dB upstream, 6.60 dB downstream
11:22:52, 15 Feb.
( 93.890000) DSL line rate: 448 Kbps upstream, 6176 Kbps downstream
and Helpdesk info:
Modulation:G.992.1 Annex A
BTW Speedtest:
Download speedachieved during the test was - 5.63 Mbps
 IP Profile for your line is - 5.45 Mbps
Could a mod investigate what's going on, please? I still want the connection changing to ADSL2+.
Thanks,
Tony
Message 8 of 18
the mods will get back to you after the email you submitted.  you are in a queue of other customers waiting for mod help and they will contact you either by email or phone when your email reaches top of queue.  at present that can take 5 working days - just patience
Message 9 of 18
i would suggest re contacting the mod helping you it looks like the upgrade has not yet been activated
Tonyh10
Message 10 of 18
I'll give it another 24 hours.
