Moderator
Moderator
Message 11 of 11
Re: At Wit's End
Hi @Wolfi1982,
Reading your post I can understand your frustration, I'm sorry to hear about the difficulties you have had in get your Infinity service. If you send me in your details I'll be able to take a look at what is happening with your order.
Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
