gavsafc
Message 1 of 67
BB Speed & Disconnections
So, since 26th August my BB speed has gone from 6mb to barely 3mb and my HHB 3 keeps disconnecting (2 times since writing this post). I've tried quiet line test (nothing wrong) hard restart to no evail (like bt asks you to on website) new equipment and checking all wires and bt box on wall. Nothing has worked & my speeds won't go back to normal. It's happening on all my devices wireless & wired. Can't be bothered to phone them & speak to some Indian person called John or Susan who blatantly read from a script & are no help whatsoever, I wonder if bt fix this if I tell them I'm cancelling with immediate effect? They dont seem to care IMO. Now I wish I didn't change provider 4 months ago as bt are not living up to expectations with their fancy equipment and "we don't slow you down" promise, what a load of ****. I've had a stable connection for the past 4 days and 16hrs and its just reset itself in the past 10 mins, it's as if they don't want your speeds back up after stable connections??
66 REPLIES 66
Message 2 of 67
Re: BB Speed & Disconnections
can you post your adsl router stats and run btspeedtester and when forst test completes then run diagnostic test and post reults please
are you conencted to test socket?  did you try quiet line test?
gavsafc
Message 3 of 67
Hi imjolly once again, I have no test socket & quiet line test is fine, I will post stats when I get on laptop as I'm unable from an ipad.
Message 4 of 67
hi  did look back to previous post.
just post when you can.  do you have extension sockets or just one socket?
gavsafc
Message 5 of 67
Just 1 socket with phone line coming in to it. It's not the socket with the test inside tho. No extension cables or nothing.
Message 6 of 67
ok  just post stats when you can
gavsafc
Message 7 of 67
here are adsl stats (seems better than previous but still not what i was getting) running bt tester now.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 02:48:04
Downstream:4.773 Mbps
Upstream:826 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):15.2 dB / 8.6 dB
Line attenuation (Down/Up):44.3 dB / 25.6 dB
Output power (Down/Up):19.8 dBm / 12.6 dBm
FEC Events (Down/Up):380 / 14
CRC Events (Down/Up):0 / 1
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):363 / 37203
Message 8 of 67
you look as if you have been in a banded profile due to all the disconnections you are still in a banded profile but i would expect in the next few days you will get another reset and you will then get a further noise margin drop providing the connection remains stable your speed will then increase again and will continue until you reach the default 6db setting
this link explains more about banding http://forumhelp.dyndns.info/speed/speed_drop.html
gavsafc
Message 9 of 67
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 4.99 Mbps
0 Mbps4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 4.99 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 4.31 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 0.65 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.65Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
So when i was placing my bt order months ago i was told on the phone by an employee that i would recieve between 7 - 11 speeds. clearly im not. i know this may look normal and show no real problems but my speed has dramatically reduced over the past 1 and a half weeks and hub disconnects by itself. i was getting faster speeds with my previous provider so how can bt say this is normal, wish i hadnt changed tbh.
gavsafc
Message 10 of 67
could this explain why the hub reset itself twice this morning and speed increased slightly, is this the normal process to get back to normal?
