AJBesty
Newbie
Message 1 of 6
BT Broadband reduction from 8mbs to below 2mbs!
My internet speeds massively reduced in recent weeks. When conducting a speed test I am now only receiving around 1.5-2mbs. It is now too slow to stream certain websites like Sky Go and HD Youtube videos, on WiFi and with an ethernet cable!
I have resent my router and left if for a few days but found no improvement.
Can anyone help out to improve my broadband speed?
5 REPLIES 5
Message 2 of 6
Re: BT Broadband reduction from 8mbs to below 2mbs!
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
AJBesty
Newbie
Message 3 of 6
I have uploaded the above images, not sure if this is correct or if anything further is required?
Thank You
Message 4 of 6
Can you enter your phone number and post results. Remember to delete number. https://www.btwholesale.com/includes/adsl/main.html
SuperSajuuk
Message 5 of 6
Based on the SNR Noise margin for downstream, there probably isn't any possible speed increase as it's at 3db, which is norm for ADSL2+. Can you post lines 1-12 from Troubleshooting -> Helpdesk as well as DSL Checker as requested by @imjolly?
You need to post the further diagnostic results from btspeedtester, the first test says nothing about whether your connection can be improved.
Message 6 of 6
are you connected to the test socket
