Do you mean
BT HOMEHUB 3 - BOOSTERS
Hi, What boosters/signals/amplifiers are good and compatible with the bt homehub 3.0? Which also works for windows vista, as when im in my room upstairs the wireless signals are appalin...!!
Re: BT HOMEHUB 3 - BOOSTERS
HI try the search feature type in extending wireless there are many posts there
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
[ Edited ]
I use these home plugs. One of them actually has wireless N built into them. Do a quick google and you'll find many different options Smiley Wink
They're great.
[ Edited ]
See Increasing Range Of Home Hubs
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
The boosters you guys have bought or set up , can u see improvements in the range?
The ones I use are powerline adaptors. One of them plugs in near your home hub and you plug an etherner cable between the 2. You then put the other device in the area of your home that gets a poor signal. You can buy ones that are wired only, so that you plug an ethernet cable into the second one then either into your computer or another wireless router OR some home plugs come with a wireless device in them.
A quick google search of "powerline wireless" brings up a few options Smiley Wink
got to agree they work very well and are very reliable
Try a Search
