Chewster
Newbie
Message 1 of 6
BT Home Hub 3 Not compatible with BT phone line?
Can anyone explain this?
I have just got off the telephone with my favorite call centre, BT Support.
To cut a Very long story short i was told that the BT Home Hub V3 is not compatible with th BT line.
Has anyone else had this?
Confused? not the only one.
Tags (4)
5 REPLIES 5
Message 2 of 6
Re: BT Home Hub 3 Not compatible with BT phone line?
welcome to the forum
I wonder if what support was saying was tha the HH3 is not compatible with BB talk nor can it be used like a dect base station
Distinguished Guru
Message 3 of 6
Hi Chewster and welcome
Ah, the joys of the call centre!!
The V3 WILL work on a BT line - it's the BBTalk that won't
Guess the 'ears' doesn't know what the elbow is doingSmiley Very Happy
-+-No longer a forum member-+-
Chewster
Newbie
Message 4 of 6
Haven't got or want BBtalk. Ive got a Netgear router at the mo running quite happlily (although BT dont hand out the router settings too easlily, had to get them from a third party forum).
BT hub - BT line, dosnt work. Netgear Hub - BT Line, works.
go figure.
Tags (4)
Message 5 of 6
sounds like a faulty hub - not unknown and more common than you think
Message 6 of 6
Hi worth noting bt do provide the information for configuring a non bt router for future reference here is the bt link http://bt.custhelp.com/app/answers/detail/a_id/644/~/how-do-i-configure-my-non-bt-router-to-work-wit...
