pandarock32
Message 1 of 7
BT Home Hub 4 event log
Hi Everyone
I have a home hub 4, and noticed this constantly in the event log:
21:52:26, 03 May.BLOCKED 1 more packets (because of Packet invalid in connection)
21:52:25, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 173.194.65.155:80->86.141.91.124:55255 on ppp0)
21:52:21, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.179.51:80->86.141.91.124:55248 on ppp0)
21:52:20, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 80.239.137.104:80->86.141.91.124:55247 on ppp0)
21:48:55, 03 May.(118320.860000) Admin login successful by 192.168.1.130 on HTTP
21:48:43, 03 May.(118309.080000) New GUI session from IP 192.168.1.130
21:48:40, 03 May.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:55323->157.56.194.23:443 on ppp0)
21:48:38, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.64:55317->184.50.162.217:443 on ppp0)
21:47:42, 03 May.(118248.210000) Lease requested
21:37:45, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 208.46.117.204:80->86.141.91.124:54271 on ppp0)
21:35:57, 03 May.BLOCKED 1 more packets (because of Packet invalid in connection)
21:35:57, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 198.78.221.126:80->86.141.91.124:50220 on ppp0)
21:34:38, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:57563->54.201.29.164:443 on ppp0)
21:34:37, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:53120->54.201.29.164:443 on ppp0)
21:34:34, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:59096->54.201.29.164:443 on ppp0)
21:34:33, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:49493->54.201.29.164:443 on ppp0)
21:34:32, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:59303->54.201.29.164:443 on ppp0)
21:34:30, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:53280->54.201.29.164:443 on ppp0)
21:34:29, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:53647->23.32.8.35:443 on ppp0)
21:34:28, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:52880->23.32.8.35:443 on ppp0)
21:34:25, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:57994->54.201.29.164:443 on ppp0)
21:34:24, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:51493->54.201.29.164:443 on ppp0)
21:34:23, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:64884->54.201.29.164:443 on ppp0)
21:34:21, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:61678->54.201.29.164:443 on ppp0)
21:34:18, 03 May.BLOCKED 1 more packets (because of Packet invalid in connection)
21:34:17, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:53528->54.201.29.164:443 on ppp0)
21:34:15, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:54214->54.201.29.164:443 on ppp0)
21:34:12, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:54451->54.201.29.164:443 on ppp0)
21:34:09, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:51847->23.34.178.106:443 on ppp0)
21:33:20, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:63872->31.13.72.112:443 on ppp0)
21:33:19, 03 May.BLOCKED 19 more packets (because of Packet invalid in connection)
21:33:18, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:62686->198.78.221.126:80 on ppp0)
21:33:01, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 80.239.137.98:80->86.141.91.124:64029 on ppp0)
21:30:47, 03 May.wlan1: STA 84:7a:88:53:f7:02 IEEE 802.11: Client disassociated
21:30:09, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 80.239.137.122:80->86.141.91.124:61591 on ppp0)
21:30:04, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 80.239.137.98:80->86.141.91.124:61586 on ppp0)
21:30:02, 03 May.BLOCKED 1 more packets (because of First packet is Invalid)
21:30:00, 03 May.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.87:43375->173.194.65.138:443 on ppp0)
21:29:58, 03 May.BLOCKED 5 more packets (because of First packet is Invalid)
21:29:56, 03 May.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.87:55832->173.194.65.138:443 on ppp0)
21:29:55, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 80.239.137.98:80->86.141.91.124:61583 on ppp0)
21:29:51, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 80.239.137.98:80->86.141.91.124:61582 on ppp0)
21:29:50, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:61576->54.215.195.204:443 on ppp0)
21:29:40, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.187.160:443->86.141.91.124:61570 on ppp0)
21:29:39, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.187.160:443->86.141.91.124:61569 on ppp0)
21:29:39, 03 May.BLOCKED 1 more packets (because of Packet invalid in connection)
21:29:39, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.167.40:80->86.141.91.124:61568 on ppp0)
21:29:37, 03 May.BLOCKED 1 more packets (because of Packet invalid in connection)
21:29:36, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.182.165:80->86.141.91.124:61561 on ppp0)
21:29:36, 03 May.BLOCKED 4 more packets (because of Packet invalid in connection)
21:29:35, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:61554->54.200.192.165:443 on ppp0)
21:29:35, 03 May.BLOCKED 5 more packets (because of Packet invalid in connection)
21:29:34, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:64972->54.186.19.164:443 on ppp0)
21:29:28, 03 May.BLOCKED 1 more packets (because of Packet invalid in connection)
21:29:26, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:56103->50.18.217.218:443 on ppp0)
21:29:25, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:51503->50.112.174.81:443 on ppp0)
21:29:24, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.188.19:443->86.141.91.124:51200 on ppp0)
21:29:20, 03 May.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.71:56407->54.201.63.197:443 on ppp0)
21:29:19, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.188.19:443->86.141.91.124:55894 on ppp0)
21:29:17, 03 May.BLOCKED 2 more packets (because of Packet invalid in connection)
21:29:17, 03 May.(117142.930000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->9308, internal ports: 9308, internal client: 192.168.1.71
21:29:16, 03 May.IN: BLOCK [9] Packet invalid in connection (TCP 23.214.188.19:443->86.141.91.124:64466 on ppp0)
21:29:13, 03 May.(117139.090000) Lease for IP 192.168.1.71 renewed by host PS4-b0-05-94-88-0f-d5 (MAC b0:05:94:88:0f:d5). Lease duration: 1440 min
21:29:13, 03 May.(117139.090000) Device connected: Hostname: PS4-b0-05-94-88-0f-d5 IP: 192.168.1.71 MAC: b0:05:94:88:0f:d5 Lease time: 1440 min. Link rate: 144.4 Mbps
21:29:13, 03 May.(117139.010000) Lease requested
21:29:12, 03 May.
wlan0: STA b0:05:94:88:0f:d5 IEEE 802.11: Client associated
Is this OK? I read on a similar thread that it was the firewall but as mine is on 'allow all traffic' does that mean there is a problem? By the way the ip adress that mostly comes up, 192.168.1.71 is my ps4 I was streaming a video at the time
6 REPLIES 6
Message 2 of 7
Re: BT Home Hub 4 event log
I would suggest for your safety that the hub firewall is activated it is there for your protection
pandarock32
Message 3 of 7
Ok thanks, I will activate it. Are the log events normal?
Message 4 of 7
yes they are
pandarock32
Message 5 of 7
UPDATE Uh-oh, I just checked the log one last time as a video I was watching simply failed to load and saw it was suddenly blocking hundreds of packets at a time. I then did a speed test and got a 100% packet loss. I'm not sure this is normal now
pandarock32
Message 6 of 7
It's ok, I realised it could be safari that was doing it (I'm on a macbook air) I then tried in chrome both the video and speedtest and it worked fine, on safari my ping was 105 and in chrome 70
Message 7 of 7
solved the problem - nice and easy change of browser
