Do you mean
Newbie
Accepted Solution
BT Home Hub has stopped working. Power light does not show.
The title says it all. The power system seems to have failed. Item is about 2 years old. What do I do please?
Martin
Re: BT Home Hub has stopped working. Power light does not show.
hi welcome to the forum
Yo need to contact the help line and get the send you a replacement hub you may have to take out a new contract
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
