Froofpin
Message 1 of 4
BT Homehub 5 keeps losing wired connection
Hi,
Recently my HH5 has been losing internet connection every few hours, although the blue light remains on. Within a few minutes I get reconnected on my PC which is connected via ethernet. Wireless devices also lose connection during these moments. The loss of connection seems to be exacerbated when I join any online game server. For example the connection will be fine while browsing on chrome and then when I join any game server (game: Battlefield 3) I will immediately be disconnected within seconds of entering the game, and the warning symbol will appear on network status in system tray.
Below is the log of when I got disconnected (by my clock the game crashed at ~17:11, having attempted to join the game ~2 min beforehand)
17:15:48, 18 Jul.( 2669.810000) Wire Lan Port 4 up
17:15:45, 18 Jul.( 2666.810000) Device disconnected: Hostname: Unknown-​bc-​5f-​f4-​67-​6e-​f0 IP: 192.168.1.23 MAC: bc:5f:f4:67:6e:f0
17:15:45, 18 Jul.( 2666.820000) Wire Lan Port 4 down
17:15:06, 18 Jul.( 2627.620000) Wire Lan Port 4 up
17:15:03, 18 Jul.( 2624.620000) Wire Lan Port 4 down
17:10:39, 18 Jul.BLOCKED 11 more packets (because of ICMP replay)
17:10:38, 18 Jul.IN: BLOCK [7] ICMP replay (ICMP type 0 code 0 81.19.216.5-​>86.174.105.79 on ppp0)
17:08:10, 18 Jul.OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.68]:47017-​>[64.233.167.192]:7275 on ppp0)
17:06:20, 18 Jul.IN: BLOCK [16] Remote administration (TCP [31.173.185.206]:51170-​>[86.174.105.79]:22 on ppp0)
17:02:41, 18 Jul.IN: BLOCK [16] Remote administration (TCP [106.75.18.143]:45109-​>[86.174.105.79]:8080 on ppp0)
~17:16 was when the connection began working again. Could this be a firewall issue?
Any advice help on this issue would be greatly appreciated.
Kind regards
*Edit*
Hub details:
1. Product name:BT Home Hub
2. Serial number:
3. Firmware version:Software version 4.7.5.1.83.8.130.1.32 (Type A) Last updated 31/10/16
4. Board version:BT Hub 4A
5. ADSL uptime:0 days, 01:07:56
6. Bandwidth:444 / 4376
7. Data sent/received:6.5 MB / 80.1 MB
8. Broadband username:bthomehub@btbroadband.com
9. BT Wi-fi:No
10. 2.4 GHz Wireless network/SSID:BTHub4-CFW3
11. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID:BTHub4-CFW3
15. 5 GHz Wireless connections:Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic (Smart Wireless)
18. Firewall:Default
19. MAC Address:
20. VPI/VCI:0 / 38
21. Modulation:G.992.5 Annex A
22. Latency type:Interleaved
23. Software variant:-
24. Boot loader:-
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: BT Homehub 5 keeps losing wired connection
Hi @Froofpin and welcome.
I'm sorry you've having problems. Does anything else happen when the connection drops? For testing purposes are you able to try uploading a large file e.g. 5GB to an external cloud service to see whether it triggers broadband drops.
Cheers
David
Froofpin
Message 3 of 4
I am unwilling to do that because with the internet speeds I get that would take about 10 hours.
Had another disconnect today:
15:12:25, 21 Jul. (254465.410000) DSL noise margin: 13.50 dB upstream, 6.00 dB downstream
15:12:25, 21 Jul. (254464.590000) DSL line rate: 448 Kbps upstream, 5237 Kbps downstream
15:11:57, 21 Jul. (254437.390000) DSL is down after 4238 minutes uptime
15:11:57, 21 Jul. (254437.390000) ETHoA is down after 4238 minutes uptime
15:11:57, 21 Jul. (254436.840000) PPPoA is down after 4236 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
15:11:51, 21 Jul. (254430.710000) PPP LCP Send Termination Request [User request]
and these seem to be the disconnects for the previous days, they are much closer together:
00:49:28, 18 Jul. (368410.530000) DSL noise margin: 15.00 dB upstream, 6.00 dB downstream
00:49:28, 18 Jul. (368410.160000) DSL line rate: 446 Kbps upstream, 5080 Kbps downstream
00:46:29, 18 Jul. (368232.010000) DSL is down after 8 minutes uptime
00:46:29, 18 Jul. (368232.010000) ETHoA is down after 8 minutes uptime
16:20:53, 18 Jul. ( 1254.100000) DSL noise margin: 12.50 dB upstream, 6.00 dB downstream
16:20:52, 18 Jul. ( 1253.410000) DSL line rate: 444 Kbps upstream, 351 Kbps downstream
16:20:22, 18 Jul. ( 1222.980000) DSL is down after 18 minutes uptime
16:20:22, 18 Jul. ( 1222.980000) ETHoA is down after 18 minutes uptime
16:20:21, 18 Jul. ( 1222.540000) PPPoA is down after 18 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
16:20:18, 18 Jul. ( 1219.260000) PPP LCP Send Termination Request [User request]
Boudges
Message 4 of 4
Start an upload and then see if anything happens! You don't have to commit to the full 5GB.
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
