Do you mean
BT home hub 3 - Connecting using wps
My laptop has windows vista sp2 on it.
I connected the home hub to the mains supply and found the access point in the list when you go to add a connection.
As per the instructions on bts website i click on connect, and then press the wps button on the side of the hub. The wireless flashes orange on the hub, however abnout 30 seconds later is asks for the network security key.
What am i doing wrong? Also can anyone who has done it upload a video showing how it's done.
Recognised Expert
Re: BT home hub 3 - Connecting using wps
iirc only win7 (microsoft OS's) is capable of WPS. might be wrong.
Check your exchange or major service outages
If someone has given a helpful answer, please click on their Ratings star on the left-hand side. Smiley Happy ***
Pull the little flap out of the top of the back of the HH3 and enter your key into the PC then its  written on that. Its to stop unauthorised access
Recognised Expert
[ Edited ]
the wps feature mentioned, is intended to speed up the process by avoiding manually entering your key. But you will have to do this (as above) manually in vista seeing as it doesn't support Wirless Protected Setup (edit: unless someone corrects me Smiley Wink )
Distinguished Guru
Are you following the instructions in the correct order? - http://bt.custhelp.com/app/answers/detail/a_id/32232
(Should also work on Vista SP2Smiley Wink)
-+-No longer a forum member-+-
I have followed the correct order. One thing i didn't get is in the picture in the link you sent when i get to step 4 my  pc only has the top part of the box for the security key, and doesn't say like in the picture"You can also connect by pushing the button on your router".
As per my earlier post, could someone please post a video of the whole process, as that might be easier.
thanks
Distinguished Guru
Hi jack
From the above link "However, if the Windows wizard does not appear as shown, it means your computer's operating system doesn't support WPS so you shouldn't go any further".
For some odd reason, your Vista sp2 install may not support this.....
Vista SP2 supports WPS. Smiley Wink
Im on vista, SP2, mine supported it, Ive got hub 3.0 and this was last monday, just try the 2 wireless passwords on the little plastic "pull me out" bit, Smiley Very Happy
