Jitsu
Message 1 of 5
BThomehub default password
Hey guys, to stop the kids messing with the BThomeHub settings which I put in place to monitor their PS3 and Xbox usage (yes im a meany), i took off the sticker and now Ive lost the sticker Smiley Very Happy Would I have to phone BT or is there any other way to bypass this?
Many thanks....
Grumpy dad!
Message 2 of 5
Re: BThomehub default password
There is a card that comes with the hub which has the passwords on it - maybe still in the box unless thrown out
Guru
Message 3 of 5
Wouldn't it have been easier just to change the password? Just curious.
Distinguished Guru
Message 4 of 5
Well if it's a BTHHv2 type a then there's also a little white label on the undersideSmiley Wink
The admin password is repeated on there!!
But if it's a type b then you're up the creek without a paddle.
I doubt BT record which hub gets sent to customers so I'd be doubtful (based on security) they could give you the admin password based on the serial number (again on the underside).
-+-No longer a forum member-+-
Jitsu
Message 5 of 5
Yeah just found that golden little sticker on the underside Smiley Happy
Thanks for the replies
