Message 1 of 11
Big reduction in speeds.
Joined in September 2019 and was getting speeds of 3-4 Mbps and 0.45 Mbps for download and upload respectively. Quite acceptable and expected for my line. Working very well with my BT Smart Hub (HH6).
Last Sunday the download speed has been reduced to 2-3 Mbps. Might not sound much to most people, especially those on Fibre etc but when you don't have much to start with it's a big drop.
The HH6 is plugged into the master and only socket on this line. The panel has a broadband and phone line sockets provided so no need for external splitters.
Done a quiet line test and a perfectly silent line.
Nothing changed in the house at all.
The figures from DSL Checker are shown below.
Thanks for any assistance.
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in Jumper
WBC ADSL 2+Up to 2.5--1 to 4Available----
WBC ADSL 2+ Annex MUp to 2.5Up to 0.51 to 4Available----
ADSL MaxUp to 2--1 to 3.5Available----
WBC Fixed Rate1----Available----
10 REPLIES 10
Message 2 of 11
Re: Big reduction in speeds.
@Canard1066
Please could you post the actual connection information from the home hub.
Message 3 of 11
Hello.
Thank you for your reply and your assistance.
The Noise Margin has also increased dramatically from 6-7 to 15, which would certainly not help the situation.
The requested info from the Hub is shown below.
Product name:
BT Hub 6A
Serial number:
xxxxxxxxxxxxxxxxxx
Firmware version:
SG4B1000E01E
Firmware updated:
01-Jan-0001
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 0 Hours 2 Minutes 44 Seconds
Data rate:
448 Kbps / 3.23 Mbps
Maximum data rate:
984 / 3444
Noise margin:
17 dB / 15.3 dB
Line attenuation:
54.5 dB
Signal attenuation:
31.5 dB / 54.5 dB
VPI / VCI:
0/38
Modulation:
G_992_1_ANNEX_A
Latency type:
Fast Path
Message 4 of 11
connection time only few minutes was that manual reset or hub dropping connection
you appear to be on adslmax and probably better on adsl2 which may not give more down speed but would give about 100% increase in up speed
Message 5 of 11
@imjolly Thank you for your reply.
The problem appears to be reflected in my download noise margin going from around 6 to 15+ dB
It would seem that the profile for the line needs to be refreshed, as well as a possible fault.
Message 6 of 11
the normal down noise margin is about 6db so at 15db that suggests a problem with your line hence why I asked if drop a few minutes ago was manual reset or router dropping connection.  if router/hub does this happen often
Message 7 of 11
Hello.
It was a manual attempt by me.
HH6 seems to have been very stable. I keep an eye on tech. log.
Moderator-Retired
Message 8 of 11
Hi @Canard1066,
Welcome to the Community and thanks for taking the time to post.
I think @imjolly is spot on and that change is noise margin is down to a possible fault on the line. I've sent you a Private Message with details on how you can get in contact with the mod team so that we can take a look into this for you.
Matt
Message 9 of 11
Hello.
Thank you for your very prompt reply.
I have replied to your private message with the requested information.
Moderator
Moderator
Message 10 of 11
Hi @Canard1066 I wanted to check that since we spoke earlier in the week that the speeds have remained at the normal speed you were getting.
Post back and let me know.
cheers
John
