jinky123
Message 1 of 23
Broadband Speed Cap
I have had download speeds of 9Mbps for ages and ages and from the 1st of April (can you believe it!) a fault developed on the line which took Openreach over 2 weeks to fix. The telephone line had rubbed itself away on a tree so the line was replaced, this fixed my broadband. Now after the so called learning process my speed is now capped at 3Mbps. I know it is capable of more as my router reports the following with command adslctl info --stats (note the Max can be 8836Mbps) see below:-
What needs to be done to get this artificial speed limit lifted? As an aside I have been logging both my download speed and the SNR for months and months so I know when my telephone line is good and capable of better perfomance than this.
Oh and I must see about getting a refund for my 2 weeks of no-show broadband. Router is a DG843GT.
Thanks.
-Jim
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 8000
Channel: FAST, Upstream rate = 1005 Kbps, Downstream rate = 3064 Kbps
Link Power State: L0
Mode:                   ADSL2+
Channel:                Fast
Trellis:                U : ON / D : ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):       4.8             5.9
Attn(dB):       45.0            23.1
Pwr(dBm):       0.0             12.8
Max(Kbps):      8836            1004
Rate (Kbps):    3064            1005
22 REPLIES 22
Message 2 of 23
Re: Broadband Speed Cap
you need to show a stable connection for 3/5 days and your speed should start to increase automatically if after then it has not improved then the forum mods should be able to help you with a reset
getting a refund on loss of broadband however is a different matter and very unlikely to happen you should be able to claim a line rental refund if your phone service was affected by the fault
Message 3 of 23
Can you add the connection time to your stats please
jinky123
Message 4 of 23
It has been learning for over 5 days since the line was fixed with no reset or disconnects. Line speed is just the same at 3036kbps.
jinky123
Message 5 of 23
Mode:            ADSL2+
Channel:        Fast
Trellis:        U:ON /D:ON
        Down        Up
SNR (dB):    5.3        5.9
Attn(dB):    45.0        23.1
Pwr(dBm):    0.0        12.8
Max(Kbps):    10328        1008
            G.dmt framing
K:        7(0)        47
R:        14        8
S:        1        4
😧        160        4
            ADSL2 framing
MSGc:        106        10
B:        6        46
M:        1        4
T:        8        3
R:        14        8
S:        0.0717        5.9393
L:        2340        264
😧        416        4
            Counters
SF:        4276426        4045500
SFErr(CRCErr):    0        0
RS:        3831678312        3334902
RSCorr:        74763        0
RSUnCorr:    0        0
HEC:        0        0
OCD:        0        0
LCD:        0        0
Total Cells:    497035401        696789
Data Cells:    10835504        2319
Drop Cells:    0
Bit Errors:    0        0
ES:        6363        0
SES:        2309        0
UAS:        2403        0
AS(Uptime):    68774
INP:        9.95        0.48
PER:        16.08        17.81
delay:        7.46        5.93
OR:        55.71        7.18
Bitswap:    1183        1227
Total uptime:    856111
Total time = 1 days 22 hours 56 min 40 sec
SF  = 53219037
CRC = 137047
LOS = 71
LOF = 138
ES  = 6363
Latest 1 day time = 22 hours 56 min 40 sec
SF  = 5129139
CRC = 1
LOS = 0
LOF = 0
ES  = 1
Latest 15 minutes time = 11 min 40 sec
SF  = 43532
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 15 minutes time = 15 min 0 sec
SF  = 55944
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 1 day time = 24 hours 0 sec
SF  = 5368869
CRC = 1033
LOS = 2
LOF = 18
ES  = 37
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF  = 55944
CRC = 0
LOS = 0
LOF = 0
ES  = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF  = 56006
CRC = 0
LOS = 0
LOF = 0
ES  = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF  = 56006
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Showtime Drop Reason:    8000
Last Retrain Reason:    8000
Message 6 of 23
if you are still using the dg834gt can you go into router then router status then show statistics at the bottom and post the information which you can now see please
Message 7 of 23
you are showing under two days stable connection at the moment so you are still getting disconnections
jinky123
Message 8 of 23
Have been connected for 121+ hours which by my reckoning is 5 days, no disconnects and still no speed increase, still the same at 3064 kbps down and 1005 kbps up.
Mode:            ADSL2+
Channel:        Fast
Trellis:        U:ON /D:ON
        Down        Up
SNR (dB):    4.6        6.0
Attn(dB):    45.0        23.1
Pwr(dBm):    0.0        12.8
Max(Kbps):    10092        1020
            G.dmt framing
K:        7(0)        47
R:        14        8
S:        1        4
😧        160        4
            ADSL2 framing
MSGc:        106        10
B:        6        46
M:        1        4
T:        8        3
R:        14        8
S:        0.0717        5.9393
L:        2340        264
😧        416        4
            Counters
SF:        27142036        25676316
SFErr(CRCErr):    1649        0
RS:        2844428358        1704957
RSCorr:        2467063        10
RSUnCorr:    69321        0
HEC:        1441        0
OCD:        27        0
LCD:        0        0
Total Cells:    3154608623        1941817
Data Cells:    304538156        340857
Drop Cells:    0
Bit Errors:    0        0
ES:        6527        0
SES:        2336        1
UAS:        2403        0
AS(Uptime):    436498
INP:        9.95        0.48
PER:        16.08        17.81
delay:        7.46        5.93
OR:        55.71        7.18
Bitswap:    6082        6705
Total uptime:    1223835
Total time = 1 days 5 hours 5 min 25 sec
SF  = 76084647
CRC = 138696
LOS = 71
LOF = 138
ES  = 6527
Latest 1 day time = 5 hours 5 min 25 sec
SF  = 1139457
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Latest 15 minutes time = 5 min 25 sec
SF  = 20207
CRC = 0
LOS = 0
LOF = 0
ES  = 0
SF  = 56006
CRC = 0
LOS = 0
LOF = 0
ES  = 0
SF  = 5372476
CRC = 372
LOS = 0
LOF = 0
ES  = 25
SF  = 55944
CRC = 0
LOS = 0
LOF = 0
ES  = 0
SF  = 55944
CRC = 0
LOS = 0
LOF = 0
ES  = 0
SF  = 56006
CRC = 0
LOS = 0
LOF = 0
ES  = 0
jinky123
Message 9 of 23
Got a £7.32 refund of broadband rental, I suppose it's better than nothing.
jinky123
Message 10 of 23
That's because it was over the 5 days with no disconnects, I just restarted the router hence the 2 days in my cut and paste of the stats.
