ppb
Message 1 of 3
Broadband Speed Cut
Has anyone seen/heard of this before?
Speed into my Home Hub 4  is 12.1Mbps according to BT speed check. However Speed Check falls over at this point saying it cannot test speed at the computer! Tested at least ten times with same results.
Independent speed checkers show speed at computer is 5 to 6Mbps; i.e. half of incoming speed! Can anyone explain this?  Connection between hub and computer is hard wired. BT help say nothing wrong with Hub must be fault with my machine. BUT I've had the same result from three different machines one of which was brand new/built from scratch!
Thanks.
2 REPLIES 2
Message 2 of 3
Re: Broadband Speed Cut
if on adsl with HH4 then you need to go to the logs and look for last time the hub restarted and you should see 2 line for connection speed and noise margin
can you copy and paste here please
enter phone number and post results  remember delete number  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
run btspeedtester and when first test completes run diagnostic test and post results  http://www.speedtest.btwholesale.com/
ppb
Message 3 of 3
Sorry but I've tried everyway I can think of to get this info to you but for some reason I can't cut/paste, copy, screen grab, etc. any of the info you have requested.
