svxmonster
Message 1 of 3
Broadband connection
Could someone please take a look at my connection as i think the snr margin and Attenuation is a bit high as i can compare to a second line in the house. Also connection keeps droping every couple of days so it doesnt come out of training period.
2 REPLIES 2
Message 2 of 3
Re: Broadband connection
You posted in May but never came back after using new filter in test socket
you need to post stats from your router and try quiet line test
svxmonster
Message 3 of 3
its still the same problem since i last posted. ive used different filters and still connected to master socket and still nothing ive also tried using a different modem router and still no luck. I keep noticing this just before is resets: PPP LCP Send Termination Request [User request]. If that helps.
