Finkk
Message 1 of 84
Broadband dips same time every day from 4pm onwards
Not sure if anyone else has this issue. For the last 2 weeks only our internet suddenly drops from 6mb to 0.5mb. I can't even load a basic web page! It slowly tends to crawl back up to 6mb about 30 minutes later. Runs fine and then about an hour later does it again.
Is it possible something is interfering during the afternoon. Could someone be doing something fairly draining? As i work from home and my job is creating websites and email campaigns, i can't work now from 4pm onwards. I just wondered if anyone else had any ideas or heard of this before? It's exactly the same time every day.
I have called BT but they tests show 8mb to us, even though i was trying to load a web page at the time i called them!
Any help or advice welcome! 🙂
83 REPLIES 83
Message 2 of 84
Re: Broadband dips same time every day from 4pm onwards
Do you have something on your pc that backup data at that time?
Are you using wifi or cable connection?
Finkk
Message 3 of 84
Hi am on Mac with backup that runs once an hour every hour. Been the same set up for the last 2 years. Unfortunately this has only just started 😞 am using cable not wifi, again same as it's always been. So frustrating! 🙂 i first thought maybe someone was doing bulk mailing or something, my old work had an issue similar and it ended up being something causing interference and BT had to block them 😞
Message 4 of 84
Are any problems showing at your exchange these links may help you
http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
can you please run the further diagnostics part of the BT speed test this  test appears after the first test completes http://speedtest.btwholesale.com/
Finkk
Message 5 of 84
Oh thanks for links! Very useful 🙂 unfortunately no reported problems. I called BT and they said all looked fine to them. I can't help thinking something causes it to dip at those times. Something between the exchange and me!
Message 6 of 84
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Finkk
Message 7 of 84
Oh i am so sorry! It's my first time here! Ok so Home Hub 3.0. I'll need to grab ADSL info in the morning. I'm not at my desk now 😞 as the dips only happen between certain times i need to run the speed test then. Thanks everyone! I will come back with more info then! 🙂
Message 8 of 84
Ok no problem there is always someone around
Moderator
Moderator
Message 9 of 84
No need to apologise Finkk,
We were all new at one stage or another!
Welcome aboard Smiley Wink
Robbie
Finkk
Message 10 of 84
Good morning 🙂 OK ADSL Stats are:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 14:45:49
Downstream:7.336 Mbps
Upstream:976 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):8.5 dB / 6.1 dB
Line attenuation (Down/Up):36.4 dB / 21.8 dB
Output power (Down/Up):20.4 dBm / 12.8 dBm
FEC Events (Down/Up):0 / 168
CRC Events (Down/Up):236411 / 44220
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):453156 / 282183
Error Seconds (Local/Remote):6358 / 9278
