Message 21 of 29
Re: Broadband disconnection issues.
I have asked a forum moderator to help you they will post their contact link here
Moderator
Moderator
Message 22 of 29
We should hopefully be able to do that for you @TcwH.
Get in touch with us by clicking on my user name and then on contact the mods. We'll get back in touch with you within the next few days.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
TcwH
Message 23 of 29
I can't see a contact the mods option (unless I'm being blind), I clicked on your name.
Message 24 of 29
TcwH
Message 25 of 29
Yeah I'm logged in clicked both of your names but it just shows your recent posts.
Message 26 of 29
I am not a moderator so that explains mine not showing the link
I will ask a mod to make the link available to you
Moderator
Moderator
Message 27 of 29
Hi @TcwH,
Can you check it again for me please as it may not have been showing to you:
DanielS
Kudos”Kudos”
TcwH
Message 28 of 29
Yep it works now, email sent, thanks.
Moderator
Moderator
Message 29 of 29
Hi Everyone, Just to confirm that interleaving was removed and this resolved the issue.
Cheers
John
Community ModeratorJohnC
Kudos”Kudos”
