jellybabygm
Message 1 of 14
Broadband drops, only comes up with restart
I am having continual intermittent broadband drop outs. Only a restart of the Hub will fix it.
After phoning support they suggest filter / internal line etc.
Just wondered if anyone had any knowledge..
I have also had one time where I couldn't even log on to the hub.
Time	Message
27/02/2012 20:49	LOGIN User tried to login on [HTTP] (from 192.168.1.67)
27/02/2012 20:49	LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
27/02/2012 20:48	xDSL linestate up (downstream: 3840 kbit/s, upstream: 448 kbit/s; output Power Down: 18.0 dBm, Up: 12.5 dBm; line Attenuation Down: 54.0 dB, Up: 31.5 dB; snr Margin Down: 6.5 dB, Up: 15.0 dB)
27/02/2012 20:48	LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
27/02/2012 20:48	xDSL linestate down
27/02/2012 20:48	LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
27/02/2012 20:47	xDSL linestate down
27/02/2012 20:47	LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
27/02/2012 20:47	LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
27/02/2012 20:46	LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
27/02/2012 20:46	LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
27/02/2012 20:45	FIREWALL event (1 of 14): enabled rules
27/02/2012 20:45	PPP link down (Internet) [86.130.78.5]
27/02/2012 20:40	SNTP Synchronised to server: 213.123.26.170
27/02/2012 20:29	FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 4.69.151.178 Dst ip: 86.130.78.5 Type: Time Exceeded Code: Time to Live exceeded in Transit
27/02/2012 20:17	UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
27/02/2012 20:17	UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
27/02/2012 19:40	SNTP Synchronised again to server (213.123.20.170)
27/02/2012 18:40	SNTP Synchronised again to server (213.123.20.170)
27/02/2012 17:40	SNTP Synchronised again to server (213.123.20.170)
27/02/2012 16:40	SNTP Synchronised again to server (213.123.20.170)
27/02/2012 15:40	SNTP Synchronised to server: 213.123.20.170
27/02/2012 14:40	SNTP Synchronised to server: 213.123.26.170
27/02/2012 13:40	SNTP Synchronised to server: 213.123.20.170
27/02/2012 13:06	FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 66.252.0.201 Dst ip: 86.130.78.5 Type: Time Exceeded Code: Time to Live exceeded in Transit
27/02/2012 12:40	SNTP Synchronised again to server (213.123.26.170)
27/02/2012 11:40	SNTP Synchronised to server: 213.123.26.170
27/02/2012 10:40	SNTP Synchronised to server: 213.123.20.170
27/02/2012 09:47	FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 66.252.0.201 Dst ip: 86.130.78.5 Type: Time Exceeded Code: Time to Live exceeded in Transit
27/02/2012 09:40	SNTP Synchronised again to server (213.123.26.170)
27/02/2012 08:53	FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 98.126.20.164 Dst ip: 86.130.78.5 Type: Destination Unreachable Code: Port Unreacheable
27/02/2012 08:40	SNTP Synchronised to server: 213.123.26.170
27/02/2012 07:40	SNTP Synchronised again to server (213.123.20.170)
27/02/2012 06:40	SNTP Synchronised again to server (213.123.20.170)
Message 2 of 14
Re: Broadband drops, only comes up with restart
Welcome to this customer to customer forum.
To enable forum members to help you, could you please read the web page that is shown below, which asks you to do a few checks first, and has some helpful hints.
Also, can you specify which home hub you are using.
When you have done that, please follow the instructions at the end, and post the results here, so members can offer advice. Thank you.
Speed and disconnections
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
jellybabygm
Message 3 of 14
quite test - fine
speed test - errored
Hub - 1.5
Message 4 of 14
We need the full ADSL statistics as requested at the end of the document, otherwise the forum members will be unable to help.
jellybabygm
Message 5 of 14
Uptime:	0 days, 22:53:03
Modulation:	G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]:	448 / 3,872
Data Transferred (Sent/Received) [MB/MB]:	13.16 / 128.06
Output Power (Up/Down) [dBm]:	12.5 / 18.0
Line Attenuation (Up/Down) [dB]:	31.5 / 54.0
SN Margin (Up/Down) [dB]:	14.0 / 6.5
Vendor ID (Local/Remote):	TMMB / IFTN
Loss of Framing (Local/Remote):	0 / 0
Loss of Signal (Local/Remote):	1 / 0
Loss of Power (Local/Remote):	0 / 0
Loss of Link (Remote):	0
Error Seconds (Local/Remote):	26 / 0
FEC Errors (Up/Down):	0 / 95,809
CRC Errors (Up/Down):	0 / 1,461
HEC Errors (Up/Down):	0 / 1,376
Line Profile:	Interleaved
Message 6 of 14
Are you connecting using wireless or Ethernet cable?
jellybabygm
Message 7 of 14
wireless
Message 8 of 14
jellybabygm wrote:
wireless
Its quite probable that its the wireless that is causing the home hub to lock up, especially as I see you have some applications mapping ports via uPnP.
Can you try using a direct cable connection?
jellybabygm
Message 9 of 14
What apps would this likely be?
Message 10 of 14
Whatever this device is. If you do not know what it is, then disable uPnP on the home hub.
