Message 31 of 42
Re: Broadband keeps dropping out
you can see the 2 resets - 1 on 8th and another on 9th.  just need to wait and see if a new hub will help but if not looks like engineer visit
Sprightly47
Message 32 of 42
The hub should be delivered today.  I'll keep you posted.
Looking at the log this morning, the last reconnect was on the 9th.
08:44:08, 09 Mar.	(134580.530000) DSL noise margin: 5.90 dB upstream, 6.20 dB downstream
08:44:06, 09 Mar.	(134578.870000) DSL line rate: 1136 Kbps upstream, 6648 Kbps downstream
08:43:16, 09 Mar.	(134528.950000) DSL is down after 690 minutes uptime
08:43:16, 09 Mar.	(134528.950000) ETHoA is down after 690 minutes uptime
08:43:16, 09 Mar.	(134528.530000) PPPoA is down after 690 minutes uptime [Waiting for Underlying Connection (WAN DSL - Up)]
08:43:12, 09 Mar.	(134525.030000) PPP LCP Send Termination Request [User request]
 There are no WAN events logged since. Is this significant? Is the noise margin acceptable, or, pardon the pun, marginal?
Also, how can I increase the up time from 690 minutes and the lease time (I think you suggested this earlier but I cant find any way to do it) from 1440 minutes? And what's this about User Request? I've asked before, but I never "request" termination other than by doing a reset, either when asked by a technician or in desperation. Neither was the case at 08:43:12 on the 9th. We went out at 06:30 and did not return until well after 19:00!
Many thanks.
Sprightly47
Message 33 of 42
By the way, how do you give a rating above 1? The star will only respond to the first click. And in another post I saw a reference to mod group and an Icon on your profile. Like many others, I can't see it, only a list of you you've helped.
Message 34 of 42
you can't give anymore that 1 star to a post
not sure about mod group and icon in profile   are you talking about contacting mods?
Sprightly47
Message 35 of 42
Hmm. Saw some had scores of 2 and 3. oh well. As to the moderator group, I've checked where I saw it in the thread about drop outs and slow speed, and it's under Forum/About, not where I thought the text said it was which was Moderator profile. Sorry.
The new hub has arrived but as there have been no WAN events since the one I posted again this morning, I'm going to leave well alone for a day or two and see what happens. I've just checked the TR069 log too, and the last " session closed due to error: No response" message was at the same time as the last "DSL is down...." message in the WAN log (Monday 9th when I was not here), so I'm assuming whatever the fault was that had our Broadband going up and down like a yo yo and slowing to a crawl (or stopping) in the evenings has maybe been fixed? Recognising of course that BT maintain there was no fault outside my property. Hmm. We'll see. Anyway, I'll let you know what happens over the next few days, and then maybe I can leave you in peace and close out the thread with a "Solved". By the way, how do you do that? I've never found the button/box/menu choice. Thanks for your help and suggestions.
Message 36 of 42
if you see a star with 2+ the that is the number of people who liked the post as everyone can only give 1 star
if you get to situation of 'solved' then select the post you think helped most then go to options on the right of that post and then 'mark as accepted solution'
Sprightly47
Message 37 of 42
That's my problem. The only "Mark" under options drop down on the right is "Mark as New". The only other options are things like "Print" , "Bookmark", "Subscribe", "Highlight" and "Report as inappropriate".
Moderator
Moderator
Message 38 of 42
Hi Sprightly47,
You can only mark threads that you have started 'As accepted soloution' This thread was started by EurIng so the accepted solution option is only available to them.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Message 39 of 42
thanks Neil  forgot that sprightly47 was not originator
Sprightly47
Message 40 of 42
Re: Line Fault is Known by BT but when will it be repared?
I seem to have "lost" the original thread Re: Broadband keeps dropping out so I'm posting in this one with the same title at the start. As previously posted, everything seemed OK after 9th at 08:44; until the 17th that is. However ther was a total power brownout (63V mains) for 1hr 22min in the whole Malmesbury area in the morning on the 17th, so that would explain the disconnect. However, as you will see from the log listing below, it took until the early hours of the 18th to sort its self out. Still have had no explanation of what the original fault was though, and no, I have not installed the replacement Home Hub, and have no intention of doing so as it never was the source of the fault.
Does anyone out there know what the fault was in the BT system? Have those with the same problem also seen it magically disappear since the 9th?
03:06:45, 18 Mar.	(45201.950000) WAN operating mode is DSL
03:06:45, 18 Mar.	(45201.950000) Last WAN operating mode was DSL
03:06:43, 18 Mar.	(45199.900000) PPPoA is up - VPI: 0, VCI:38
03:06:43, 18 Mar.	(45199.880000) CHAP authentication successful
03:06:43, 18 Mar.	(45199.620000) CHAP Receive Challenge
03:06:43, 18 Mar.	(45199.620000) Starting CHAP authentication with peer
03:06:43, 18 Mar.	(45199.610000) PPP LCP Receive Configuration ACK
03:06:43, 18 Mar.	(45199.590000) PPP LCP Send Configuration Request
03:06:43, 18 Mar.	(45199.590000) PPP LCP Receive Configuration Reject
03:06:43, 18 Mar.	(45199.590000) PPP LCP Send Configuration ACK
03:06:43, 18 Mar.	(45199.590000) PPP LCP Receive Configuration Request
03:06:43, 18 Mar.	(45199.390000) PPP LCP Send Configuration Request
03:06:09, 18 Mar.	(45165.970000) PPPoA is down after 750 minutes uptime [Disconnected]
14:35:34, 17 Mar.	( 131.240000) PPP IPCP Receive Configuration ACK
14:35:34, 17 Mar.	( 131.220000) PPP IPCP Send Configuration ACK
14:35:34, 17 Mar.	( 131.210000) PPP IPCP Receive Configuration Request
14:35:34, 17 Mar.	( 130.800000) PPP IPCP Send Configuration Request
14:35:34, 17 Mar.	( 130.790000) PPP IPCP Receive Configuration NAK
14:35:29, 17 Mar.	( 125.920000) PPP IPCP Send Configuration ACK
14:35:29, 17 Mar.	( 125.920000) PPP IPCP Receive Configuration Request
14:35:27, 17 Mar.	( 124.180000) PPP IPCP Send Configuration Request
14:35:27, 17 Mar.	( 124.180000) WAN operating mode is DSL
14:35:27, 17 Mar.	( 124.180000) Last WAN operating mode was DSL
14:35:25, 17 Mar.	( 121.790000) PPPoA is up - VPI: 0, VCI:38
14:35:25, 17 Mar.	( 121.760000) CHAP authentication successful
14:35:25, 17 Mar.	( 121.690000) CHAP Receive Challenge
14:35:25, 17 Mar.	( 121.690000) Starting CHAP authentication with peer
14:35:25, 17 Mar.	( 121.690000) PPP LCP Receive Configuration ACK
14:35:25, 17 Mar.	( 121.660000) PPP LCP Send Configuration Request
14:35:25, 17 Mar.	( 121.660000) PPP LCP Receive Configuration Reject
14:35:25, 17 Mar.	( 121.660000) PPP LCP Send Configuration ACK
14:35:25, 17 Mar.	( 121.660000) PPP LCP Receive Configuration Request
14:35:25, 17 Mar.	( 121.430000) PPP LCP Send Configuration Request
14:35:21, 17 Mar.	( 118.190000) ETHoA is up - VPI: 0, VCI:35
14:35:21, 17 Mar.	( 118.170000) DSL is up
14:35:20, 17 Mar.	( 117.020000) DSL noise margin: 5.90 dB upstream, 6.10 dB downstream
14:35:18, 17 Mar.	( 115.270000) DSL line rate: 1140 Kbps upstream, 6648 Kbps downstream
14:34:06, 17 Mar.	( 42.900000) WAN Auto-sensing running.
13:12:19, 17 Mar.	( 131.250000) PPP IPCP Receive Configuration ACK
13:12:19, 17 Mar.	( 131.220000) PPP IPCP Send Configuration ACK
13:12:19, 17 Mar.	( 131.220000) PPP IPCP Receive Configuration Request
13:12:19, 17 Mar.	( 130.810000) PPP IPCP Send Configuration Request
13:12:19, 17 Mar.	( 130.810000) PPP IPCP Receive Configuration NAK
13:12:14, 17 Mar.	( 125.910000) PPP IPCP Send Configuration ACK
13:12:14, 17 Mar.	( 125.910000) PPP IPCP Receive Configuration Request
13:12:12, 17 Mar.	( 123.870000) PPP IPCP Send Configuration Request
13:12:12, 17 Mar.	( 123.870000) WAN operating mode is DSL
13:12:12, 17 Mar.	( 123.870000) Last WAN operating mode was DSL
13:12:10, 17 Mar.	( 121.800000) PPPoA is up - VPI: 0, VCI:38
13:12:10, 17 Mar.	( 121.780000) CHAP authentication successful
13:12:10, 17 Mar.	( 121.680000) CHAP Receive Challenge
13:12:10, 17 Mar.	( 121.680000) Starting CHAP authentication with peer
13:12:10, 17 Mar.	( 121.680000) PPP LCP Receive Configuration ACK
13:12:10, 17 Mar.	( 121.660000) PPP LCP Send Configuration Request
13:12:10, 17 Mar.	( 121.660000) PPP LCP Receive Configuration Reject
13:12:10, 17 Mar.	( 121.660000) PPP LCP Send Configuration ACK
13:12:10, 17 Mar.	( 121.660000) PPP LCP Receive Configuration Request
13:12:10, 17 Mar.	( 121.480000) PPP LCP Send Configuration Request
13:12:06, 17 Mar.	( 118.080000) ETHoA is up - VPI: 0, VCI:35
13:12:06, 17 Mar.	( 118.080000) DSL is up
13:12:05, 17 Mar.	( 117.150000) DSL noise margin: 5.90 dB upstream, 6.60 dB downstream
13:12:04, 17 Mar.	( 115.920000) DSL line rate: 1076 Kbps upstream, 6648 Kbps downstream
13:10:51, 17 Mar.	( 42.960000) WAN Auto-sensing running.
08:44:17, 09 Mar.	(134589.360000) PPP IPCP Receive Configuration ACK
08:44:16, 09 Mar.	(134589.040000) PPP IPCP Send Configuration Request
08:44:16, 09 Mar.	(134589.030000) PPP IPCP Receive Configuration NAK
08:44:15, 09 Mar.	(134588.200000) PPP IPCP Send Configuration ACK
08:44:15, 09 Mar.	(134588.200000) PPP IPCP Receive Configuration Request
08:44:14, 09 Mar.	(134586.660000) PPP IPCP Send Configuration Request
08:44:14, 09 Mar.	(134586.660000) WAN operating mode is DSL
08:44:14, 09 Mar.	(134586.660000) Last WAN operating mode was DSL
08:44:12, 09 Mar.	(134584.540000) PPPoA is up - VPI: 0, VCI:38
08:44:12, 09 Mar.	(134584.530000) CHAP authentication successful
08:44:12, 09 Mar.	(134584.410000) CHAP Receive Challenge
08:44:12, 09 Mar.	(134584.410000) Starting CHAP authentication with peer
08:44:12, 09 Mar.	(134584.410000) PPP LCP Receive Configuration ACK
08:44:12, 09 Mar.	(134584.270000) PPP LCP Send Configuration Request
08:44:12, 09 Mar.	(134584.270000) PPP LCP Receive Configuration Reject
08:44:12, 09 Mar.	(134584.270000) PPP LCP Send Configuration ACK
08:44:12, 09 Mar.	(134584.270000) PPP LCP Receive Configuration Request
08:44:11, 09 Mar.	(134584.220000) PPP LCP Send Configuration Request
08:44:09, 09 Mar.	(134581.330000) ETHoA is up - VPI: 0, VCI:35
08:44:09, 09 Mar.	(134581.330000) DSL is up
08:43:12, 09 Mar.
