Message 11 of 14
Re: Broadband miserable speed
Then you just have a standard ADSL connection.
If the phone went dead, then that would indicate a problem on the external line.
Which master phone socket do you have?
Message 12 of 14
Hi I have the illustration No.6.
Message 13 of 14
They can suffer from problems, and are not ideal on an ADSL connection, as they introduce loss owing to the over complex circuitry  inside the filter section.
If you have a spare microfilter, then plug it into the real test socket which is located behind the filter section. See if the speed improves, and the disconnections stop.
Connect it up like this.
Message 14 of 14
Hi thanks for that will remove the facia and try a filter in the test socket if it occurs. Appreciate the help.
