AdamB1406
Newbie
Message 1 of 3
Broadband not working. Phone line works
Hi all.
Line coming into the house comes into a single socket which we have an adsl filter for broadband and phone. The phone line is working fine but broadband doesnt. Starting to tear my hair out a little. Is it the hub itself?
Thanks.
Adam
Moderator
Moderator
Message 2 of 3
Re: Broadband not working. Phone line works
Hi @AdamB1406 Sorry that your broadband connection is not working.
Please check out Broadband - Top Tips to get help on the forum
Is there any noise interference on the phone line? and if you are unable to get any connection can you post back and let us know what colour are the lights on your hub.
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Message 3 of 3
is this a new home?  have you had broadband on the line before from any ISP?
have you checked there are no other sockets in your home?
if you plug hub into test socket with a filter what colour is the hub light?
enter your phone number and post results  remember delete number http://dslchecker.bt.com/adsl/adslchecker.welcome
