Marg0105
Message 11 of 17
Re: Broadband poor speeds
Sorry for the delay in replying, cable found and connected directly from hub to PC, all other equipment turned off. I hope this is the information you requested.
Thank you
Message 12 of 17
can you go to hub manager then troubleshooting then helpdesk and post your stats please
Guru
Message 13 of 17
So far ... so good.
Marg0105
Message 14 of 17
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ53326175
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 13/07/17
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 11:23:40
6. Data rate:12000 / 66918
7. Maximum data rate:18471 / 76119
8. Noise margin:10.0 / 8.2
9. Line attenuation:18.3 / 17.2
10. Signal attenuation:18.2 / 17.2
11. Data sent/received:57.9 MB / 754.7 MB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-QXKX
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-QXKX
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:a0:1b:29:79:72:b2
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Sorry I posted the wrong thing last night - is this the info you need?
Guru
Message 15 of 17
Well that looks to be a good connection Marg ...
SNRm is a tad high but should resolve with time.
Your BT speedtest and line profiles are set, and giving you good throughput on ethernet.
Eventually once it stabilises and you use good cable management and placement, you might even see g.inp
Do a review of stuff and refer to the recommendations for placement and keep power and data cables tidy and segregated as much as you can.
I think you've been unlucky somewhere with placement.
Marg0105
Message 16 of 17
Thank you - I now have to find how to permanently fix the wire draped across the front of of the house. Cat Happy or maybe how to move the hub to a more central point.......and perhaps be grateful the ex plumber didn't do any plumbing on our house. "*glug glug*" Cat LOL
Guru
Message 17 of 17
Or ... you could save up, and get Openreach to install the latest SSFP in a more "usable" place. £££s but worth it. 🙂
Good luck.
