Message 11 of 21
Re: Broadband slowed down a couple of weeks ago
Yep, thanks john46, I've done that.
Message 12 of 21
Hi john46 -- do you know how long it takes for the mods to get stuck into things?  It's been three days since I contacted them, but perhaps that's normal.
Many thanks,
James
Message 13 of 21
The mods are busier than normal and can take 3/5 working days to contact you personally by either email or phone
Moderator
Moderator
Message 14 of 21
Hi @jamesbristol I called earlier sorry I could not reach you. I have run a few checks on your connection and it's highlighting that this could be a fault with the internal set up.
To help eliminate this please will you identify which socket type you have. You can view the different sockets at www.bt.com/help/socket
If possible can you connect the only the hub to your test socket with the microfilter and see if the connection improves.
Cheers
John
Message 15 of 21
Hi @JohnC2 -- sorry, just got to the phone when it stopped!  Yes, I can jig things around and try that.  I've got a master socket with a single socket.  It's the left one in the series of four pictures.  Feel free to call again if it's convenient.
Many thanks,
James
Distinguished Guru
Message 16 of 21
That's fine, I can see that @JohnC2 is going to be calling you again tomorrow.
DanielS
Message 17 of 21
@DanielS Thanks for that.  Meantime, I've disconnected the front plate and have the modem plugged into the test socket.
Many thanks,
James
Message 18 of 21
@JohnC2 Thanks for your help earlier -- good results so far!  Talk to you on Monday.
Many thanks,
James
Moderator
Moderator
Message 19 of 21
Hi @jamesbristol Thanks for taking my call earlier and glad to hear that your connection has improved and remained stable now.
Cheers
John
Message 20 of 21
Yes, all good -- over 4M now!  Very many thanks to @JohnC2 and @john46 -- really appreciate all your help on this.
James
