Distinguished Guru
Message 21 of 27
Re: Broadband speed gone very slow after noisy line problem fixed
Stats page:  Noise margin (Down/Up)    30.5 dB / 6.0 dB
Log Entry:  snr Margin Down: 6.4 dB, Up: 29.6 dB
Did you notice that the stats page and the log entry seem to be inconsistent in the reported noise margins with the high/low figures being reversed?
I assume that's just a display bug in the HH2 firmware?
simon9999
Message 22 of 27
Well the internet went down again just now, so I reset the router to it's default settings. Have also ordered a TP-LINK which should arrive on Tuesday.
If the internet doesn't go down I won't install it though until hopefuly the line speed goes back to normal. If it does go down I will install it and see what happens.
simon9999
Message 23 of 27
Well I think the problem is solved now 🙂
After being connected for just over a day, the noise margin has gone down to 6db, and the downstream is now about double the speed that it was before all the problem started! Fingers crossed that everything is ok now, thanks for you help. 🙂
simon9999
Message 24 of 27
Well the line has dropped a couple of times over the last day, but the download speed hasn't suffered (yet).
Got the new router today, will install it next time we lose internet and will see what happens.
Distinguished Guru
Message 25 of 27
Could you post the new Homehub stats now things gave improved?
Would also be useful to compare against later if you swap the routers.
simon9999
Message 26 of 27
Sure, here they are:
Connection information
Line stateConnected
Connection time0 days, 21:14:13
Downstream17,753 Kbps
Upstream1,216 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)6.3 dB / 5.7 dB
Line attenuation (Down/Up)19.0 dB / 10.3 dB
Output power (Down/Up)0.0 dBm / 12.8 dBm
Loss of Framing (Local)12
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)6006 / 0
CRC Errors (Down/Up)1 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)14
Will let you know when I swap the routers.
Distinguished Guru
Message 27 of 27
The down noise margin target has been set back to 6dB. This is used at connection time and determines the synced down connection rate.
Possibly a line reset was performed by the system (or someone)? That would set the up/down noise margin targets back to the default of 6dB and trigger a reconnection.
Anyway, looking good speed wise. Will it now be stable and no longer keep dropping the connection is the big question?
