Zeebus
Message 1 of 24
Broadband speed has gone from 2mbs to 0.288kps with a high upload speed,since phoneline fault.
Ive been with bt broadband for 15+ years and have never had a problem.. such as i have now. Ive had 2mbs connection, since moving into my home for the last 3+years. Ive never had any real issues with it.. till now. About 9 days ago me and the wife, had come back home to find out telephone and broadband not working. So i phoned bt up the next day using my father in laws home phone. Who lives just a couple houses down the road.( theyre with bt also and their connection is still running at 2mbs). After i got on the phone and came back home. Low and behold the telephone and broadband were working again..only my broadband had come back absolutely garbage. To the point where i cant stream on netflix or youtube. I gave it a couple of days to settle. Before i phoned bt back up. Then got me to reset my hub and the usual stuff, then told me to ring back in a few days if nothing had changed. So nothing had changed so i rang up again. I was told that my line looked fine and they couldnt find anything wrong. They told me that they would refresh the line and that their manager would call me back in a couple of days. Still was the same. The fact that my upload speed is higher than my download speed is a bit puzzling as well. I checked my noise margain is: ( 112.940000) DSL noise margin: 9.40 dB upstream, 6.00 dB downstream. And ive had no noise on the quiet test line. My phone is plugged into the test socket. It literally feels like someone has literally moved my connection line further away from my house. And im at my wits end.. its been driving me crazy. Me and the wife are due to have a baby next month, and i dont really want to have to stress out about my broadband. I dont particularly want to leave bt, but if it isnt aorted i may have no choise:(. I just hope i can get some answers here.
23 REPLIES 23
Message 2 of 24
Re: Broadband speed has gone from 2mbs to 0.288kps with a high upload speed,since phoneline fault.
can you post some stats from your hub/router
can your run btspeedtester and when first test completes then run diagnostic test and post results  http://speedtest.btwholesale.com/
enter your phone number and post results  remember to delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
Zeebus
Message 3 of 24
Which particualr stats would you like from my bthub4?
Message 4 of 24
http://www.kitz.co.uk/adsl/frogstats.php
looking for connection speed
noise margin
attenuation and any others on same page
Zeebus
Message 5 of 24
from the first test on the btwholesale site : download speed(mbs) 0.24 upload speed(mbs): 0.00 ping latency(ms) 0.00. Further diagnostics results shows Best effort test : download 0.24mbps upload: 0.06mbps
XRaySpeX
Recognised Expert
Message 6 of 24
Please post all the text on the Further Diagnostics page incl. IP Profiles.
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Zeebus
Message 7 of 24
1. Product name:    BT Home Hub
2. Serial number:    +068340+NQ42027948
3. Firmware version:    Software version 4.7.5.1.83.8.130.1.32 (Type A) Last updated 14/10/16
4. Board version:    BT Hub 4A
5. ADSL uptime:    0 days, 02:22:31
6. Bandwidth:    444 / 288
7. Data sent/received:    8.3 MB / 47.6 MB
8. Broadband username:
9. BT Wi-fi:    Yes
10. 2.4 GHz Wireless network/SSID:    BTHub4-QSHP
11. 2.4 GHz Wireless connections:    Enabled (802.11 b/g/n (up to 300 Mb/s))
12. 2.4 GHz Wireless security:    WPA and WPA2
13. 2.4 GHz Wireless channel:    1
14. 5 GHz Wireless network/SSID:    BTHub4-QSHP
15. 5 GHz Wireless connections:    Enabled (802.11 a/n (up to 300 Mb/s))
16. 5 GHz Wireless security:    WPA2
17. 5 GHz Wireless channel:    Automatic (Smart Wireless)
18. Firewall:    Default
19. MAC Address:    40:f2:01:36:e1:6a
20. VPI/VCI:    0 / 38
21. Modulation:    G.992.3 Annex A
22. Latency type:    Interleaved
23. Software variant:    -
24. Boot loader:
17:34:40, 16 Nov.( 112.030000) DSL line rate: 444 Kbps upstream, 288 Kbps downstream
Zeebus
Message 8 of 24
VDSL Range A (Clean)2.111.20.80.8Available----Yes--
VDSL Range B (Impacted)2.10.81.10.50.6Available----Yes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 2--1 to 3.5Available--------
WBC ADSL 2+ Annex MUp to 2Up to 0.51 to 3.5Available--------
ADSL MaxUp to 1.5--1 to 2.5Available--------
WBC Fixed Rate0.5 ----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date16-05-2017
Message 9 of 24
all the problems with connection have resulted in your conenction ending up in a banded profile  if you can maintain connection the banding should release in 3/5 days stable connection  if you get 3+ days stable and still nothing then repost router stats and we can see if mods will help
https://www.plus.net/help/archive/broadband/broadband-terminology-guide/?supportarchive
XRaySpeX
Recognised Expert
Message 10 of 24
Are there no attenuation figures anywhere?
It looks like the DLM system has put you on a banded profile in response to past errors on your line, at the top of the lowest of these ADSL Banded Profiles. You need to ask BT to get the DLM reset in order to remove any banding. However should significant errors persist the DLM will reapply banding.
