Do you mean
Newbie
Broadband speed in my area
Hi
First time on here so please excuse me if this question has been asked a million times before!
Can anyone tell me how to find out if my exchange is going to be updated? I live in a house which is only 12 years old in a large 'new town' and I believe there are several exchanges that service the area. Some roads, that I can see from my house, appear to be able to get 'fast' connection, however I'm only able to get a 1mbps speed!!
Can I ask BT to upgrade? Is this something my neighbours and I can campaign for?
Thanks in advance
Chris
Guru
Re: Broadband speed in my area
[ Edited ]
Hi,
Your exchange is probably ADSLMax enabled giving your speeds of up to 8mb. The upgrade your probably talking about is the upgrade to BTw's 21cn network which enables ADSL2+ at your exchange. ADSL2+ is upto 20mb.
You can check if your exchange is going to be upgraded here: http://www.samknows.com/broadband/broadband_checker
However if you have a long line then a good stable line on ADSLMax may not be a good stable line on ADSL2+ as ADSL2+ is more aggressive to any noise on your line.
Once BTW and Openreach have upgraded your exchange it can take days/weeks/months till your line is upgraded to ADSL2+ as they are manual transferred to the new equipment in the exchange in batches.
If your on a ling line then you might be moved to BTw's 21cn network but kept on ADSLMax.
If your able to supply your ADSL Line Statistics and a BT speedtest we might be able to tell you if you will benefit from ADSL2+.
1) ADSL Line Stats Help
If you have a BT Home Hub like the one below...
Then:
1) Go to http://192.168.1.254 or http://bthomehub.home
2) click Settings
3) Click Advanced Settings
4) Click Broadband
5) Click Connection or sometimes called ADSL (see picture Below)
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3)
2) can your post your BT Speedtest results by using http://speedtester.bt.com (not beta version) [best done with a wired connection ie Ethernet]
3) Are you connected to the master socket?
4) Have you tried the test socket?
cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
DL Speed 2.10 Mbps
UL Speed 0.37 Mbps
Ping Latency 50.88 ms
Not good!!
Guru
Thanks,
Can you please post your adsl Line statistics.
ADSL Line Statistic Help:
Then:
2) click Settings
4) Click Broadband
You will need to copy and past all the adsl line statistics ( Including HEC, CRC and FEC errors). You may need to click " More Details"
There are more useful links on Keith's website here: If you have an ADSL connection, please select this link
 cheers
Try a Search
